AP doesn't show in VC after upgrade to firmware 8.5
  • 1.  AP doesn't show in VC after upgrade to firmware 8.5
    Posted Jun 21, 2019 04:32 AM
    Hello Everyone,
    i have two model of AP (305 & 207), I recently perform a firmware upgrade from 6.4 to 8.5 but not all AP is appearing on my access point list on my virtual controller despite that all of them are reachable and is working properly.
    any quick resolution?
  • 2.  RE: AP doesn't show in VC after upgrade to firmware 8.5
    Posted Jun 21, 2019 10:16 AM
    How did you upgrade the cluster? They each use different firmwares. Are they both upgraded to 8.5? If not, you will need to upgrade the other one to the same version/build.
  • 3.  RE: AP doesn't show in VC after upgrade to firmware 8.5
    Posted Jun 21, 2019 01:46 PM
    Hello Jerrod,
    Thanks for your reply.
    Actually i upload the firmware via a tftp server and both AP is updated to version 8.5.
    i have two AP model in my cluster namely 207 and 305 &
    in GUI only 8 AP is being displayed in a total of 60 AP. All 60 APS is pingable and is working.
  • 4.  RE: AP doesn't show in VC after upgrade to firmware 8.5
    Posted Jul 01, 2019 01:47 AM
    the issue is solve actually their's a bug to firmware version 8.5 so i downgrade it 8.4 and everything is working normally.
  • 5.  RE: AP doesn't show in VC after upgrade to firmware 8.5
    Posted Jul 09, 2019 06:35 PM
    TAC has a patch if you are running 8.5 with Airwave 8.2.9.   Contact TAC and they will patch Airwave.
