AP Doesn't show up to be added to Visual RF
  • 1.  AP Doesn't show up to be added to Visual RF
    Posted Nov 14, 2012 09:29 AM
    Adding som 40 AP105s  to a floor plan and all but one of them shows up in the list of APs to choose from.
    I have not added this AP to any other floor plan, it is provisioned the same as all the others both on the controller and in AirWave.
    I have tried both matching the planned AP a managed AP and adding a deployed device. The AP doesnt show up in the list using either method.
    suggestions?
    Thanks.
  • 2.  RE: AP Doesn't show up to be added to Visual RF
    Posted Nov 14, 2012 09:30 AM
    How long ago did you add them to AirWave?   VisualRF is sometimes a bit behind in "seeing" them.   When I see this, I typically restart VisualRF.  This usually forces it to see newer APs.
  • 3.  RE: AP Doesn't show up to be added to Visual RF
    Posted Nov 14, 2012 10:16 AM
    Added them about 48hrs ago now so they should have been detected.  All but the one have.
    Will try restarting visual RF and see what happens.
  • 4.  RE: AP Doesn't show up to be added to Visual RF
    Posted Nov 14, 2012 12:46 PM
    Another thing to try is to check the /var/log/visualrf/visualrf.log to make sure there's no crashes.  This is the main log for VisualRF activity.
