ap down time
  • 1.  ap down time
    Posted Jan 03, 2021 11:11 PM
    Hi team,
    How we can check the AP down time from aruba controller using command ? i ahve no access to  GUI, we acre using cli
    Regards & Thanks
    Francis
    nidhin pereira
  • 2.  RE: ap down time
    Posted Jan 03, 2021 11:23 PM
    you can use "show version" command  and that will give you the uptime from which you can deduce the downtime.
