AP enters upgrade loop after controller upgrade 6.1.2.2 - 6.1.2.5
  • 1.  AP enters upgrade loop after controller upgrade 6.1.2.2 - 6.1.2.5
    Posted Nov 25, 2011 12:44 AM
    Hi
    I just upgraded my controllers from 6.1.2.2 -> 6.1.2.5
    All Campus AP's came up without any problems, but all RAP's entered a loop, where it reboot,s and then start upgrading again.
    This happens both with RAP5, RAP2, and AP61.
    Any ideas how to solve this ?
    Jone
  • 2.  RE: AP enters upgrade loop after controller upgrade 6.1.2.2 - 6.1.2.5
    Posted Nov 25, 2011 01:15 AM
    Type "show log system 50" to see why those RAPs are rebooting.
  • 3.  RE: AP enters upgrade loop after controller upgrade 6.1.2.2 - 6.1.2.5
    Posted Dec 06, 2011 07:04 AM
    Hi
    Sadly, There is not much info on my controller about reboot reason. I will bring one of my RAP to my office today and look at the AP, what it's doing.
    I have verified that it is happening on AP61 (as RAP), and also on RAP-2.
    I also think it is happening on RAP-5.
    Vil verifiy today.
  • 4.  RE: AP enters upgrade loop after controller upgrade 6.1.2.2 - 6.1.2.5
    Posted Dec 06, 2011 12:05 PM
    Please check AP-ROLE and make sure FTP is allowed there.
    I would recommend you to open a TAC ticket to debug the issue.
    To troubleshoot the issue, here is what I would check:
    1. session on port 4500 from RAPs outer ip. You cn check this in datapath session table.
    2. If session is there , that check for "show crypto isakmp sa" from CLI enable mode.
    3. If it is there, check for "show crypto ipsec sa". Also check Inner ip-address of the RAP here.
    4. Do "show user-table verbose" and see whether RAP is in the AP-Role or not.
    5. From the inner IP address of the RAP. check datapath session on port 21 (FTP), 8209 (Sec-PAPI).
    Hope this will help.
  • 5.  RE: AP enters upgrade loop after controller upgrade 6.1.2.2 - 6.1.2.5
    Posted Jul 18, 2012 08:46 AM
    Any news on this problem? I am facing the same issue.... start a endless upgrade process and reboot. I pressed reset to clear the configuration and the RAP5  has 3.3 version before the upgrade begins.
    any idea?
    thank you
  • 6.  RE: AP enters upgrade loop after controller upgrade 6.1.2.2 - 6.1.2.5
    Posted Jul 18, 2012 10:01 AM
  • 7.  RE: AP enters upgrade loop after controller upgrade 6.1.2.2 - 6.1.2.5
    Posted Nov 25, 2011 10:48 AM
    Are you using PPPoE?
  • 8.  RE: AP enters upgrade loop after controller upgrade 6.1.2.2 - 6.1.2.5
    Posted Nov 29, 2011 02:57 AM
    Hi
    I just upgraded my 620 controller from 6.1.2.4 to 6.1.2.5 and RAP-5 goes in a loop, not able to upgrade.
    I use PPPoE on the interface that holds the public IP.
    So it seems that it is a common problem.
