AP Failover to another cluster POC
  • 1.  AP Failover to another cluster POC
    Posted Mar 22, 2019 11:32 AM
    Does anyone have any info on implementing fail-over for APs to another Cluster? Simply adding a LMS backup IP (Cluster 2 VIP) in the AP group didnt work :D I know a bootstrap would occur I don't even see the AP in MM after powering off the cluster.
    Additional info: I'm using DHCP options 43 and 60 for new APs.
    Allan
  • 2.  RE: AP Failover to another cluster POC
    Posted Mar 22, 2019 12:14 PM
    Are you powering off the cluster after the AP is connected to the cluster?
  • 3.  RE: AP Failover to another cluster POC
    Posted Mar 31, 2019 02:07 PM
    Yes I have two MCs in each Cluster.
    I powered off each Cluster member. Watched the A-AAC change to the S-AAC.
    Powered off the last MC of cluster.
    AP never reported into BLMS (VIP) of Cluster 2.
  • 4.  RE: AP Failover to another cluster POC
    Posted Mar 31, 2019 02:17 PM
    When you say " you don't even see the AP in the MM" what command are you using the see the AP in the MM?
  • 5.  RE: AP Failover to another cluster POC
    Posted Sep 17, 2019 02:08 PM
    Is there a specific guide on how AP Failover to another cluster should be configured? i.e. where is the hierarchy the AP-Groups, VLANs, and WLANs should be created? I can find articles stating it can be done using LMS and B-LMS, but no suggestions on the actual configuration.
  • 6.  RE: AP Failover to another cluster POC
    Posted Sep 17, 2019 03:17 PM
    Do you want to make an AP failover to a specific controller in the cluster?
    For more information on how AP load balancing is configured,
    refer the AOS UG 8.5.0.0 (Page: 373)
  • 7.  RE: AP Failover to another cluster POC
    Posted Sep 17, 2019 03:24 PM
    Say I have 2 different datacenters, and a cluster in each datacenter. If datacenter 1 cluster goes down I want the APs that typically terminate to that cluster to failover to datacenter 2 cluster.
  • 8.  RE: AP Failover to another cluster POC
    Posted Sep 17, 2019 04:27 PM
    So the scenario is like this.
    Datacenter 1 - cluster 1 - APs terminated on a controller in this cluster.
    Datacenter 2 - cluster 2 - APs should failover to a controller in this cluster if the controller that the APs are terminated to on cluster 1 fails.
    Try this solution
    Cluster 1 - This will have a MC which acts as a LMS to the APs (say 10.0.0.1 )
    Cluster 2-  Choose a controller which should act as a B-LMS to the AP when they fail over. (10.0.0.2)
    Assuming that the datacenters have L3 connectivity, configure a vrrp instance as follows.
    On Cluster 1 MC
    vrrp 1
    vlan <vlan used>
    ip address 10.0.0.1
    priority 110
    preempt
    authentication <choice of password>
    description Preferred-Master
    no shutdown
    On cluster 2 Preferred MC
    vrrp 1
    vlan <vlan used>
    ip address 10.0.0.2
    priority 110
    preempt
    description Backup-Master
    no shutdown
    Now go to the AP system profile configured for the APs, can be viewed using the command "show ap system-profile"
    open the ap system-profile using the command
    ap system-profile <name of the profile used>
    Configure
    lms-ip <cluster 1 MC>
    Bckup-lms-ip <cluster 2 MC>
    Save and deploy the changes.
  • 9.  RE: AP Failover to another cluster POC
    Posted Sep 18, 2019 12:27 AM
    A_RAK is correct, that is the way of doing such a scenario. One thing to add. Instead of using a specific controller IP for LMS and Backup LMS I would use the Cluster VRRP for this entry. This makes sure, that the LMS or Backup LMS is available regardless of the status of a single controller.
    The AP will first connect to the LMS IP. This should be the cluster VIP of cluster 1. it will then learn all Controllers in cluster 1 and will create tunnels to the AAC and S-AAC in Cluster 1. The Ap will only failover to cluster 2 if all controllers in cluster 1 are down or not reachable. The AP will not create a standby tunnel to a controller in Cluster 2 before all Controllers in cluster 1 are down.
    Hope this gives more insights.
  • 10.  RE: AP Failover to another cluster POC
    Posted Sep 26, 2019 12:35 PM
    Would you need to have all the VLANs configure on both clusters?
    e.g. Cluster 1 allowed VLANs configured on Cluster 2, and vice versa?
  • 11.  RE: AP Failover to another cluster POC
    Posted Sep 26, 2019 01:14 PM
    Yes.  OR, you could create the WLANs (Virtual AP) with a VLAN name and then define a name to vlan number mapping on each cluster.
  • 12.  RE: AP Failover to another cluster POC
    Posted Jan 07, 2022 08:19 PM
    Do you also have to configure the same WLANs, AP Groups, Roles, and Profiles on the Cluster 2 controllers?
    If you enable pre-empt, does that take the head-ache out of moving the APs back to Cluster 1 after Cluster 1 comes back up?
    Jeremy Bradrick
  • 13.  RE: AP Failover to another cluster POC
    Posted Jan 08, 2022 01:47 PM
    Ideally, both clusters would be under the same folder, so they would have access to the same configuration.  If both clusters are not in the same folder/container, the APs will get the configuration for whatever ap-group they are in on the new cluster, which you would need to synchronize if you want the same behavior or you would have to manage two separate configurations.
    Honestly, I have seen few people fail over devices to a second cluster as a best practice.  Having a cluster is its own redundancy (APs would exhaust connecting to all controllers in a cluster before failing over).  Failing over to a second cluster provides more redundancy, but more complexity.
    Enabling pre-empt just makes things even more complicated, especially if you are not sure if only specific APs have failed over.  Long story short, your ultimate redundancy should just be a single cluster, unless you need site redundancy.  If you have a backup-lms pointing to a second cluster, that is where your APs will end up if they have failed to connect to all controllers in the first cluster.  Without pre-empt, that becomes your new APs cluster and they will "stick" to that cluster.  With pre-empt, things become more unpredictable as you will have to play the game of "where are all of my APs right now."
