AP Firewall Question
  • 1.  AP Firewall Question
    Posted Oct 08, 2014 09:14 AM
    I am running on 6.4.1.0 and am experiencing the bug mentioned in the release notes for 6.4.2.1 which i have pasted below.  The part in question is the bold part.  I would like to change this setting on my current install but i cannot find this setting for the life of me.  I have searched high and low and cannot find any reference to it.
    Symptom: Controllers were unable to see ping requests, which resulted in ping responses being
    dropped. This issue is resolved by disabling the firewall enable-stateful-icmp parameter by default.
    Scenario: This issue was observed when the firewall checked for the unsolicited ICMP echo replies and
    dropped them if there were no ICMP echo request sessions. This issue was observed in the 7200 Series
    controllers and M3 controllers running ArubaOS 6.4.1.0 and above.
  • 2.  RE: AP Firewall Question
    Posted Oct 08, 2014 09:17 AM
    You need to do it from the CLI.
    (config) #no firewall enable-stateful-icmp
  • 3.  RE: AP Firewall Question
    Posted Oct 08, 2014 09:21 AM
    Thats what thought, and looked there but did not see it even in there.  Then i run that it doesnt recognize the enable-stateful-icmp part.
    (Aruba7210) (config) #no firewall enable-stateful-icmp
    % Invalid input detected at '^' marker.
  • 4.  RE: AP Firewall Question
    Posted Oct 08, 2014 09:22 AM
    Does it accept the command without the "no"?
  • 5.  RE: AP Firewall Question
    Posted Oct 08, 2014 09:25 AM
    Nope, same behavior.  Hence why i've been so confused.....
  • 6.  RE: AP Firewall Question
    Posted Oct 08, 2014 10:13 AM
    That command worked for me, at AOS 6.4.2.1-FIPS. Not sure if maybe it's just not present in 6.4.1.0. If you run a "no firewall ?", what is the output?
    (Aruba7010) (config) #no firewall enable-stateful-icmp
    (Aruba7010) (config) #show image ver
    Partition       : 0:1 (/dev/usb/flash2) **Default boot**
    Software Version : ArubaOS 6.4.2.1-FIPS (Digitally Signed - Production Build)
    Build number    : 46041
    Label           : 46041
    Built on        : Thu Sep 18 02:50:20 PDT 2014
  • 7.  RE: AP Firewall Question
    Posted Oct 08, 2014 10:16 AM
    It does not appear that the command exists in 6.4.1.0 which is strange since its listed in the release notes.  I was hoping to get this issue fixed without upgrading as i just had to downgrade from 6.4.2.0 due to an issue with ARM that i need to open with TAC. I think there is a bug that basically set ARM to its lowest values and ignored any settings i gave it.  I can replicate it on my test controller, but i have not had a chance to see if 6.4.2.2 fixes it.  I did not see it in the release notes, so i am guessing not.
    (Aruba7210) (config) #no firewall ?
    allow-stun              Allow ICE-STUN based firewall traversal. Default
                            option is enabled
    allow-tri-session       Allow three way session when performing destination
                            NAT
    amsdu                   Enable receiving AMSDUs
    attack-rate             Configure attack rates
    bwcontracts-subnet-br.. Apply bw contracts to local subnet broadcast traffic
    cp-bandwidth-contract   Configure bandwidth contracts that protect CP
    deny-inter-user-bridg.. Disallow forwarding non-IP frames between untrusted
                            users
    deny-inter-user-traff.. Disallow forwarding any frames between untrusted
                            users
    deny-source-routing     Disallow forwarding of IP frames with source routing
                            options set
    disable-ftp-server      Disable FTP server
    disable-stateful-h323.. Disable stateful H.323 processing. Default option is
                            disabled.
    disable-stateful-sccp.. Disable stateful SCCP processing. Default option is
                            disabled.
    disable-stateful-sip-.. Disable stateful SIP processing. Default option is
                            disabled.
    disable-stateful-sips.. Disable stateful SIPS processing. Default option is
                            disabled. !! WARNING: Disable 'classify-media' CLI
                            in access-list for better performance !!
    disable-stateful-ua-p.. Disable stateful UA processing. Default option is
                            disabled.
    disable-stateful-voce.. Disable stateful VOCERA processing. Default option
                            is disabled.
    dpi                     Enable DPI Classification
    drop-ip-fragments       Drop all IP fragments
    enable-per-packet-log.. Enable per-packet logging. Default is per-session
                            logging.
    enforce-tcp-handshake   Enforce TCP handshake before allowing data
    enforce-tcp-sequence    Enforce TCP sequence numbers for all packets
    gre-call-id-processing  Enable GRE call ID processing
    imm-fb                  Triggers datapath immediate freeback of buffers.
                            Applicable to 72xx Platform only(Default disabled)
    jumbo                   Enable Jumbo frames processing
    local-valid-users       Only allow IP addresses of local subnets in user
                            table
    log-icmp-error          Log all received ICMP errors
    prevent-dhcp-exhausti.. Enable check for DHCP client-hw-address against
                            packet source mac
    prohibit-arp-spoofing   Prohibit ARP spoofing
    prohibit-ip-spoofing    Prohibit IP spoofing
    prohibit-rst-replay     Prohibit TCP RST replay attack
    session-tunnel-fib      Enable session,tunnel based forwarding. !!Warning!!
                            It is recommended to toggle this knob during
                            maintenance window or OFF peak production hours. On
                            M3 this knob will enable ONLY tunnel based
                            forwarding, session based does NOT apply to this
                            platform.
    shape-mcast             Automatically shape bursty multicast traffic
    stall-crash             Triggers datapath crash on stall detection.
    voip-wmm-content-enfo.. Enforce WMM voice priority matches flow content
  • 8.  RE: AP Firewall Question
    Posted Oct 08, 2014 10:32 AM
    I would open a TAC case to file a defect or bug as to why that command is not present (it's not in the CLI guide either).
  • 9.  RE: AP Firewall Question
    Posted Oct 08, 2014 11:27 AM
    I could check that ARM thing out on 6.4.2.2, if you have a way to replicate/diagnose
    the problem.  We haven't had time to go proofreading what ARM is doing yet, so that
    might be an opportune intro to ARM debugging for me.
  • 10.  RE: AP Firewall Question
    Posted Oct 08, 2014 11:51 AM
    Because i hate when i look for solution to things and see thread left unsolved: I loaded 6.4.2.2 on my test controller and it does appear that the command is missing from 6.4.1.0.  It does exist in 6.4.2.2 and appears to do exactly what its supposed to.  I will let TAC know but i would not expect a software update for the 6.4.1.0 version since newer tech releases are already out that address the problem.
    As far as the ARM thing in my first quick test it may be fixed as well, because its actually respecting the parameters i assign it now where as before it would always broadcast at the same (very low) power regardless of what i told it to do.
