last person joined: 8 hours ago
AP Firmware Downgrade Possible?
This thread has been viewed 22 times
  • 1.  AP Firmware Downgrade Possible?
    Posted Jul 20, 2017 06:44 AM
    I am using Aruba Central. Recently i've done upgrade of AP firmware from 6.5.2.0_59123 to 6.5.3.0_59775. After upgrade, I encounter some issue for guest Wi-Fi.
    I thinking if I downgrade AP firmware to previous version, guest Wi-Fi would have banck to normal. Is it possible to downgrade AP firmware thru Aruba Central or any other way?
    Samuel
  • 2.  RE: AP Firmware Downgrade Possible?
    Posted Aug 10, 2017 11:20 AM
    you should be able to downgrade the firmware through Aruba Central. Just go to the firmware section and once you click Update Firmware, select the Other option for Firmware Version. You can then select which version you want including earlier ones.
    If that doesn't work, then you can unlicense the affected APs, download an earlier firmware version from support.arubanetworks.com, and apply it manually through the AP's web interface.
