AP-I 205- as a controller
  • 1.  AP-I 205- as a controller
    Posted Dec 16, 2014 05:24 AM
    hey all,
    I need your advice about the AP-I 205
    I need to install this AP as a controller it need to in control 90 AP's and MAX of 1400 clients.
    it is O.K to use only one controller or its better to split it to 2 controllers?
    thanks in advance.
  • 2.  RE: AP-I 205- as a controller
    Posted Dec 16, 2014 06:01 AM
    Hi Friend,
    You mean IAP 205 ? and you want to bring up an IAP clustor with 90 APs ?
    Please clarify, I can help you on this.
  • 3.  RE: AP-I 205- as a controller
    Posted Dec 16, 2014 07:06 AM
    Ohad is speaking about InstantAP version = iAP-205
    In a single cluster there can be up to 2000 devices with the lastest firmware as far i know.  Is not a hard limit but is recommended.
    Just in AP 9x model the cluster is limited to 254 devices per cluster, but your AP is a 225 so you should be good to go!, you got the AP with the best CPU RAM of all Aruba APs.
    • How many Instants APS you can connect together?
    There is no limit as such, but the number of IAPs in that Instant network, managed by a single virtual controller, depends on the RF and also the client density.
  • 4.  RE: AP-I 205- as a controller
    Posted Dec 16, 2014 07:10 AM
    i'm asking if its o.k to control in 90 aps with one iap 205 or it's better to split the control to two controllers each one control on 45 aps
  • 5.  RE: AP-I 205- as a controller
    Posted Dec 16, 2014 07:12 AM
    Yes, you can use a single VC as long as your client ip space can handle the number of users.
    Sent from Nine<>
  • 6.  RE: AP-I 205- as a controller
    Posted Dec 16, 2014 07:14 AM
    There is no hard limit.Yes , you can.
    90 Units on 1 VC of iAP-205 will work,  there is no limit - it's all depandeds on amount of traffic & control .
