ap image preload failed result code 255
  • 1.  ap image preload failed result code 255
    Posted Nov 09, 2015 02:55 PM
    I decided to try the ap image preload feature ahead of a controller code upgrade. I attempted to use it on a M3mk1 with 4 APs in a test group. It failed. It also says (in the GUI) that to retry it, I need to reload the controller (WAT?). Here's what I see in the CLI now. Any idea what result code 255 means?
    (aruba4) #show ap image-preload status all
    AP Image Preload Parameters
    Item Value
    Status Active
    Mode Specific APs
    Partition 1
    Build 51619
    Max Simultaneous Downloads 10
    Start Time 2015-11-09 13:28:43
    AP Groups Listed for Preload
    AP Groups
    IT
    AP Names Listed for Preload
    AP Names
    xxxxxxx
    AP Image Preload AP Status Summary
    AP Image Preload State Count
    Preload failed 4
    TOTAL 4
    AP Name AP Group AP IP AP Type Preload State Start Time End Time Failure Count Failure Reason
    xxxxxxx xx xxx.xx.xxx.xx 125 Preload failed 2015-11-09 13:48:37 2015-11-09 13:48:52 5 Flash image upgrade failed: Result code 255
    xxxxxxx xx xxx.xx.xxx.xx 105 Preload failed 2015-11-09 13:48:38 2015-11-09 13:48:53 5 Flash image upgrade failed: Result code 255
    xxxxxxx xx xxx.xx.xxx.xx 125 Preload failed 2015-11-09 13:48:38 2015-11-09 13:48:52 5 Flash image upgrade failed: Result code 255
  • 2.  RE: ap image preload failed result code 255
    Posted Nov 09, 2015 02:57 PM
    Did you already upload the code to the controller and is that the partition that is listed as "default boot"?  (type show image version)
  • 3.  RE: ap image preload failed result code 255
    Posted Nov 09, 2015 04:55 PM
    Yes:
    (aruba4) #show image version
    Partition : 0:0 (/dev/hda1)
    Software Version : ArubaOS 6.4.3.2 (Digitally Signed - Production Build)
    Build number : 50323
    Label : 50323
    Built on : Wed Jun 3 15:38:12 PDT 2015
    Partition : 0:1 (/dev/hda2) **Default boot**
    Software Version : ArubaOS 6.4.3.4 (Digitally Signed - Production Build)
    Build number : 51619
    Label : 51619
    Built on : Thu Sep 10 18:19:28 PDT 2015
  • 4.  RE: ap image preload failed result code 255
    Posted May 04, 2016 12:30 PM
    Had the same issue and 255 error code with 1 AP 105 when preloading 6.4.3.7 from 6.4.3.5.
    Rebooting just the AP itself solved the issue (while the controllers were still at 6.4.3.5). Since this was the only AP out of many to fail preloading at all, I didn't pursue it further.
    show image version
    Partition           : 0:0 (/dev/usb/flash1) **Default boot**
    Software Version    : ArubaOS 6.4.3.7 (Digitally Signed - Production Build)
    Build number        : 53990
    Label               : 53990
    Built on            : Sat Feb 27 13:48:13 PST 2016
    Partition           : 0:1 (/dev/usb/flash2)
    Software Version    : ArubaOS 6.4.3.5 (Digitally Signed - Production Build)
    Build number        : 52564
    Label               : 52564
    Built on            : Mon Nov 16 15:04:25 PST 2015
