AP is down since 2024-03-21 14:29:09 because of the following reason: Hbt Timeout.
This thread has been viewed 16 times
  • 1.  AP is down since 2024-03-21 14:29:09 because of the following reason: Hbt Timeout.
    Posted 12 days ago
    Hi, in lay man terms, what does this mean
    And how do I fix this?
    Also if I wanted to run an SNMP query against my controllers, to discover which AP's are in a state of [AP is down since 2024-03-21 14:29:09 because of the following reason: Hbt Timeout.]
    Which OID would I use ?
  • 2.  RE: AP is down since 2024-03-21 14:29:09 because of the following reason: Hbt Timeout.
    Posted 12 days ago
    That means that the AP hasn't communicated with the controller for a period of time.  Fix the issue by restoring connectivity between the AP and controller.
    Carson Hulcher, ACEX#110
  • 3.  RE: AP is down since 2024-03-21 14:29:09 because of the following reason: Hbt Timeout.
    Posted 12 days ago
    Pray tell, when you say
    You mean the networking, as in looking on the switch interface ?
  • 4.  RE: AP is down since 2024-03-21 14:29:09 because of the following reason: Hbt Timeout.
    Posted 12 days ago
    Interface, physical connection, IP route, anything that might have changed between known good state and current failed state.
