AP is in group but has zero WLan's
  • 1.  AP is in group but has zero WLan's
    Posted Apr 09, 2021 02:18 PM
    Looking for advice on some AP-515's. They discover the MM just fine. We drop them in the proper group which has other AP's working nicely.
    The AP appears to provision but never starts  broadcasting wlan's. No Flags to be seen. On the AP status page you can see it has no Wlans. Any ideas? Thanks
    Ryan Hertzing
  • 2.  RE: AP is in group but has zero WLan's
    Posted Apr 09, 2021 02:47 PM
    show ap config ap-name <name of ap>
  • 3.  RE: AP is in group but has zero WLan's
    Posted Apr 12, 2021 07:54 AM
    Make sure your controller (MD) firmware version and/or DRT version is recent enough to have the AP-515 supported in your country domain. If you are on recent firmware, this should not be an issue.
