AP is keeps on rebooting
This thread has been viewed 40 times
  • 1.  AP is keeps on rebooting
    Posted Jan 09, 2018 12:54 AM
    hi to all,
    i have a 7205 controller with 6.5.4.2 OS. these 2 APs were once discovered and configured to a group however it keeps on rebooting. what could be the reason? TIA.
    see attached datapath session.
    any suggestions will be greatly appreciated
  • 2.  RE: AP is keeps on rebooting
    Posted Jan 09, 2018 02:20 AM
    Hi Harvey
    What access points are you using?
    What firmware are they on?
    There is a chance that they are locating a master controller.
  • 3.  RE: AP is keeps on rebooting
    Posted Jan 09, 2018 02:40 AM
    What kind of discovery method are you using:
    • ADP
    • DHCP
    • DNS
    Can you see / get the output from the AP console during boot?
  • 4.  RE: AP is keeps on rebooting
    MVP EXPERT
    Posted Jan 09, 2018 05:04 AM
    Also if you can, attach a console cable to the AP and let it reboota few times, this will give us further clues :)
  • 5.  RE: AP is keeps on rebooting
    Posted Jan 09, 2018 05:14 AM
    Try to factory reset and do it again.
    Make sure AP has all information to join the controller, check via console.
  • 6.  RE: AP is keeps on rebooting
    Posted Jan 09, 2018 06:04 AM
    thank you everyone for your prompt response.
    i am managing at least 17APs via DHCP ,all of them are AP305. 16APs were successfully discovered with no console or hard reset done except for 1AP. actually I was able to modify its APName and group until I noticed it goes up and down every few minutes.
    never had a chance to neither plug console nor do hard reset since it was already mounted up on ceiling
    will test your suggestions next visit.
    thank you all
  • 7.  RE: AP is keeps on rebooting
    Posted Jan 09, 2018 06:53 AM
    Do you have enough licenses on the controller? Are you sure it isn't limited to 16 licenses?
  • 8.  RE: AP is keeps on rebooting
    Posted Jan 09, 2018 06:37 AM
    @harveyysip wrote:
    hi to all,
    It almost looks like port UDP 8211 is being blocked between the AP and the controller:
