AP is not associated to Virtual Controller, Status DOWN
This thread has been viewed 23 times
  • 1.  AP is not associated to Virtual Controller, Status DOWN
    Posted Feb 04, 2019 11:45 AM
    Hi, I'm new to this Aruba Controller and AP's.
    One of my Customers is facing issue with AP's , Status Down ( AP is not associated to Vitural Controller).
    AP (Aruba AP 205H) is getting IP address but, still its down.
    Can someone help me with this issue ?
    Thanks.
  • 2.  RE: AP is not associated to Virtual Controller, Status DOWN
    MVP EXPERT
    Posted Feb 04, 2019 11:48 AM
    Is this IAP part of the same L2 broadcast domain as the existing cluster? Have any changes been made to the switch ports where the IAP is connected?
  • 3.  RE: AP is not associated to Virtual Controller, Status DOWN
    Posted Feb 05, 2019 01:30 AM
    Yes, I guess it's the part of same L2 broadcast as Idk about their network, I'm new joining in my company and senior person left the organization they just sent me to this customer who is having this issue and idk if someone has made changes to switch or not, customer has their own IT department. I asked customer has they tried to changed the LAN Ports of those APs they said yes, they changed the LAN ports but, still they were down it seems.
    Is there any way that I can resolve the issue right away ?
    Thanks.
  • 4.  RE: AP is not associated to Virtual Controller, Status DOWN
    MVP EXPERT
    Posted Feb 05, 2019 01:49 AM
    Yes, make sure the switch port is a trunk port with the native vlan set as the IAP management VLAN and any the remaining VLANs are tagged VLANs.
    If you search for the Aruba Instant VRD (sorry I haven’t got the link at the mo) this will explain further the required switch settings.
    Sent from my iPhone
  • 5.  RE: AP is not associated to Virtual Controller, Status DOWN
    Posted Feb 05, 2019 03:54 AM
    Thanks mate.
    I'll check it out.
    Appreciate.
  • 6.  RE: AP is not associated to Virtual Controller, Status DOWN
    MVP EXPERT
    Posted Feb 05, 2019 04:21 AM
    No worries, here's the link
    https://community.arubanetworks.com/t5/Validated-Reference-Design/Aruba-Instant-Validated-Reference-Design-V2-0/ta-p/456734
    Also feel free to post the logs from the VC & problematic IAP.
    show log debug
    show log system
    show log ap-debug
  • 7.  RE: AP is not associated to Virtual Controller, Status DOWN
    Posted Feb 07, 2019 02:28 AM
    Sure, I'll try to get information from client place.
    apart from that, yesterday i've noticed that on a aruba switch two ports are drawing some power and its fluctuating,
    Example Port 20 : Power Reserved : 25W and Drawn power: 5.4 W ,
    later when I check it Power Drawn : 6.4/6.5/ 33 W etc.
    if i change the switch port the AP is working perfectly fine. Is the issue with Switch port ? ONLY PoE Orange light is flashing.
    Thanks.
  • 8.  RE: AP is not associated to Virtual Controller, Status DOWN
    MVP EXPERT
    Posted Feb 07, 2019 04:16 AM
    You can rule out the switch port by plugging in a known working IAP into the switch port and see if it exhibits the same behaviour.
