AP KERNEL Syslog Message ieee80211_recv_mgmt
  • 1.  AP KERNEL Syslog Message ieee80211_recv_mgmt
    Posted Apr 02, 2015 10:00 AM
    Do you find KERNEL messages in your Syslog with this error:
    ieee80211_recv_mgmt 6273 Driver is not able to allocate node
    We are using ArubaOS 6.4.2.4 and have seen these messages from models
    124 and 125, mostly from model 124. I opened a support call and this
    is my interpretation of the answer I got:
    When the AP receives a management frame, the AP passes the frame to
    ieee80211_recv_mgmt() for processing. Data frames received from
    associated clients do not get passed off to this function. If the
    management frame is a beacon for a node that does not already exist
    in the AP’s node table, the function will make a call to something
    like ieee80211_alloc_node() to add it to the node table. If the node
    cannot be successfully added to the node table then the allocation
    routine returns NULL and ieee80211_recv_mgmt() logs the event.
    Since this error is related to a beacon from a neighbouring or interfering
    AP, the error would seem to be benign. However, when the allocation
    routine fails, I wonder if one cause could be that no space exists to
    add another node, which would seem to imply that there would be no more
    room to associate a new client either. It might be worth a closer look
    to see if the reporting AP logs the message during a time when it is
    saturated with clients.
    If I have interpreted anything incorrectly, I will rely on Aruba reviewers
    to correct me.
  • 2.  RE: AP KERNEL Syslog Message ieee80211_recv_mgmt
    Posted Sep 07, 2015 11:17 AM
    We've recently upgraded to 6.4.2.10 and I've been seeing that same error more and more.  It appears to be the AP-125's getting it.  Not sure if it's only those.
    I can confirm that for us when it's happening on an AP no clients are able to connect.  What makes it tough too is AirWave wasn't reporting anything down, so now I'm checking the aruba logs for 'KERNEL' to keep any eye on this.
  • 3.  RE: AP KERNEL Syslog Message ieee80211_recv_mgmt
    MVP
    Posted Sep 08, 2015 07:55 AM
    Had the same issues with APs. Solved it by rebooting AP only and then we didn't receive it anymore.
  • 4.  RE: AP KERNEL Syslog Message ieee80211_recv_mgmt
    Posted Sep 08, 2015 01:47 PM
    When I was on 6.4.2.8 I wasn't getting them.  With 6.4.2.10 I got 6 more today already.  Might have to open something with TAC.  Still only the AP-125s.
  • 5.  RE: AP KERNEL Syslog Message ieee80211_recv_mgmt
    Posted Sep 08, 2015 04:18 PM
    Pgemme, that should be fixed in 6.4.2.12. and it was first reported in 6.4.2.9.  You can either upgrade to 6.4.2.12 to sidestep it or downgrade to something before 6.4.2.9
  • 6.  RE: AP KERNEL Syslog Message ieee80211_recv_mgmt
    Posted Sep 08, 2015 04:30 PM
    Well, just to be clear, when I opened my case on this issue (1658205) at the beginning of March, we were running 6.4.2.4.
  • 7.  RE: AP KERNEL Syslog Message ieee80211_recv_mgmt
    Posted Sep 08, 2015 04:57 PM
    Doug,
    That is why I was very specific with pgemme. It is useful on the forum to search for a message when there is a problem, but it can be misleading unless you double check with TAC for specific circimstances and your specific situation. Pgemme should still check with TAC.
  • 8.  RE: AP KERNEL Syslog Message ieee80211_recv_mgmt
    Posted Sep 08, 2015 04:33 PM
    Thanks guys, thanks Colin.
    We were good in 6.4.2.8, not sure we ever ran 6.4.2.4 but the symptom Colin posted looks spot on. Scheduling an upgrade with change control now.  I always prefer going forward.
  • 9.  RE: AP KERNEL Syslog Message ieee80211_recv_mgmt
    Posted Sep 08, 2015 04:46 PM
    pgemme,
    Please open a case with TAC.  There are a number of things to check to ensure that you end up on the correct version of code and we are addressing what you perceive:
    1.  If you are running 6.4.2.9 through 6.4.2.10 AND
    2.  You see an access point not allowing users to attach and you run this command and get this response:
    show ap remote debug anul-sta-entries ap-name <name of ap>
    Module AP STM is busy. Please try later
    AND
    3.  It is one of these AP models:
    AP-124, AP-125, AP-120, AP-121
    AP-92, AP-93, AP-93H
    AP-104, AP-105
    RAP-3WN
    AP-134, AP-135
    RAP-155, RAP-155P
    RAP-108, RAP-109
    AP-114, AP-115
    AP-103, AP-103H
    4.  The message at the beginning of this post *could* be a symptom, but all of these other things must be happening as well.
    It is best you open a TAC case to ensure this is your issue.  It is also possible you have an unknown issue, or a different issue, but just reading symptoms on a post does not ensure that is your problem...is why you should open a TAC case.
  • 10.  RE: AP KERNEL Syslog Message ieee80211_recv_mgmt
    MVP
    Posted Sep 10, 2015 05:34 AM
    We have done a work-around together with our client to solve this issue.
    What we have done is, for all the AP-124 we have created a separate AP Group and on it then we created a separate ARM Profile, where we have disabled Client match. Then we have provisioned all the AP-124 on that group.
    For now this has solved our issue.
