This thread has been viewed 24 times
  • 1.  AP Matrix
    Posted Sep 20, 2012 02:54 PM
    Hi
    Exists a list of brands or models of AP's/AM  supported by the Airwave.
    I know that the Airwave is Multi-Vendor but I want to know more about it.
    And if it is possible know which limits or what happens with the Aps different from Aruba.
    I can use this new APs to do Tracking, heatmaps etc.?
    I want to know this because I need to integrate an old Cisco/Motorola base with new Aruba APs and of course Airwave.
    Thanks.
  • 2.  RE: AP Matrix
    Posted Sep 20, 2012 03:16 PM
    Try the supported device matrix.
    http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=8057
    If you're not getting to it directly from the link, the path is:
    Documentation tab
    Software User & Reference Guides
    AirWave
    7.5.x
    AirWave Supported Devices for 7.5.x
    Pay close attention to the latest supported firmware column.  The document pertains to devices that can be monitored/managed by AMP.  For visualization of location tracking and heatmaps, you'll be using the VisualRF portion of the product.  You should be able to add any monitored/managed device into a floor plan.  Note that the accuracy is based on the accuracy of the floor plan image and monitored/managed device placement on the floor plan.
  • 3.  RE: AP Matrix
    Posted Sep 20, 2012 04:30 PM
