HI I'm running 8.3.0.12 we have lot of mesh AP's. When we were on version 6.4 we used to be able to look at the mesh's with the web interface. Now I have to log into each controller CLI to do show ap mesh topology. It would be lot easier if I could do that from the MM dashboard.
Are you talking about viewing the Mesh APs? If so you can find it under configuration > Access Points > Mesh APs.
If your looking for Mesh configurations, you can find it under System > Profiles > Mesh.
Also, if you go to Configuration > AP Groups > Select AP Group > Mesh, you can see the Mesh APs and their information there as well.
I'm not looking for the configuration I'm looking for the page that shows the web interface version of the CLI show ap mesh topology . That shows the current RSSI and other information about the mesh. Also shows what AP is a portal and a point. The version 8 only shows all AP's configured for mesh. I know what my configuration is I like to check the RSSI.
I will include a picture
Sorry for a long delay, not checking community often...
Mesh GUI is coming in AOS 8.7. As far as seeing a 'topology' view, that will have to wait for AirWave / Central to support, not sure of that timeline.
