ArubaOS : 8.10.0.8
AP : 325,635
Client : win10
Client network : AX201,AX211
network driver : 23.40.0.4 2024/3/10
Question :
The user is connected normally and is in the same location without moving. However, the ap will keep sending physical layer messages, causing the user to change ap. If this state continues, the user will be disconnected.
show ap remote debug mgmt-frame ap-name 6FSW-006 client-mac f0:9e:4a:95:8e:e0
Controller setting :
wlan virtual-ap vap-iot(md) |
aaa-profile aaa-iot(md) |
ssid-profile ssid-iot(md) |
wmm-traffic-management-profile wmm(md) |
no mobile-ip |
vlan-mobility |
band-steering |
broadcast-filter all |
dot11k-profile dot11k(md) |
vlan 102 |
deny-inter-user-traffic |
wlan dot11k-profile dot11k(md) |
dot11k-enable |
rrm-ie-profile rrm-ie(md) |
rf dot11a-radio-profile rf11a-default(md) |
arm-profile arm11a-default(md) |
max-tx-power 18 |
min-tx-power 15 |
rf dot11g-radio-profile rf11g-default(md) |
arm-profile arm11g-default(md) |
max-tx-power 9 |
min-tx-power 6 |
interference-immunity 3 |
rf arm-profile arm11a-default(md) |
cm-report-interval 5 |
cm-sticky-min-signal 65 |
rf arm-profile arm11g-default(md) |
no 80MHz-support |
