last person joined: 8 hours ago
AP namechange
  • 1.  AP namechange
    MVP
    Posted Nov 21, 2011 06:35 AM
    When we change the name of an AP through the Aruba cli this change doesn't seem to be propagated to Airwave.
    The name in Airwave does not change untill we manually change it. Is there a way to automate changes like this?
  • 2.  RE: AP namechange
    Posted Nov 21, 2011 06:58 AM
    Select the access point you made the change to and click on "Import Settings"
  • 3.  RE: AP namechange
    Posted Nov 21, 2011 12:51 PM
    We've got some things in the works to make this happen automatically if you want it to.
  • 4.  RE: AP namechange
    Posted Nov 22, 2011 08:45 AM
    Is this option available if the AP is in monitor mode in Airwave?
  • 5.  RE: AP namechange
    Posted Nov 22, 2011 08:48 AM
    Yes, the Import Settings option has to be used because you are in monitor mode in Airwave. Otherwise, you could just change the name in Airwave, because then you would be managing your wireless from within Airwave.
  • 6.  RE: AP namechange
    Posted Apr 11, 2012 09:55 AM
    I"m trying to do the opposite right now, and manage IAP's from Airwave, I am able to change the virtual controller name, but not change any of the actual AP's.
    I can change the name of the AP's just by logging into the VC and then they propogate to AWMS, but for some reason can't do it in the opposite direction.
    Any ideas?
  • 7.  RE: AP namechange
    Posted Apr 11, 2012 11:09 AM
    AMP currently doesn't support per-AP configuration for Instant, but it is planned for an upcoming release, so stay tuned.
  • 8.  RE: AP namechange
    Posted Apr 11, 2012 01:07 PM
    Sweet, good to hear, also is there a way to configure the DHCP pool via the VC? or are we stuck with the 192.168.11.x scope?
  • 9.  RE: AP namechange
    Posted Apr 16, 2012 11:57 AM
    Are you sure that DHCP pool is coming from the VC and not something else on the network?
