AP not registering to Wireless controller
  • 1.  AP not registering to Wireless controller
    Posted Feb 15, 2015 03:35 AM
    I am configuring Aruba W-650 WLC . configured it created 2 SSIDs and 2 Vlans
    when i try to connect the AP 105. it doesn't get register or show up in WLC to be installed/provisioned.
    below is the error in wlc
    Feb 14 02:43:56 fpcli: USER: admin has logged in using serial.
    Feb 14 02:46:12 fpapps[2415]: <209801> <WARN> |fpapps| Physical link down: port 1/1
    Feb 14 02:46:49 publisher[2222]: <306510> <WARN> |publisher| Dropping message from 8212 for service '77 (service not found)'
    Feb 14 02:46:52 webui[1468]: USER:admin@172.16.51.10 COMMAND:<write memory > -- command executed successfully
    Feb 14 02:47:57 fpapps[2415]: <209801> <WARN> |fpapps| Physical link down: port 1/1
    Feb 14 02:48:40 publisher[2222]: <306510> <WARN> |publisher| Dropping message from 8212 for service '77 (service not found)'
    can anyone help here please, where or what option i would have missed to enable.
  • 2.  RE: AP not registering to Wireless controller
    Posted Feb 15, 2015 04:08 AM
    Did you factory reset the AP (Purge). if already factory reset, check the license if you have enough license please share the following outputs,
    1. "show datapath session | include <AP ip address> "
    2. "show ap database"
    Please share the above , surely we can fix the issue.
  • 3.  RE: AP not registering to Wireless controller
    Posted Feb 17, 2015 01:03 AM
    Hi Venu,
    Thanks for the reply.
    I reset the AP to factory settings and worked for me.
    I have a licence of 16 AP and 3 were in use.
    Thanks.
