AP not up in remote site(MPLS)
  • 1.  AP not up in remote site(MPLS)
    Posted Sep 02, 2014 06:55 PM
  • 2.  RE: AP not up in remote site(MPLS)
    Posted Sep 02, 2014 07:01 PM
    Was the AP before or it just not coming up ?
    How is it configured as a Campus AP or as a RAP ?
  • 3.  RE: AP not up in remote site(MPLS)
    Posted Sep 02, 2014 07:14 PM
    It is a Campus AP. being used as a Campus AP. We have MPLS network at the remote site.
    AP pings the master and vice versa.
    Everything is assigned static to AP.
    Purged the AP and set env multiple times. no result.
    Did packet capture at switch.
    heres the o/p
    192.168.255.2    - CONTROLLER
    192.168.8.7    - AP
    *Sep  2 20:43:46.864: IP: s=192.168.8.7 (GigabitEthernet0/1.10), d=192.168.255.2 (GigabitEthernet0/0.50), len 32, sending full packet
    *Sep  2 20:43:46.864:     UDP src=1204, dst=3078
    *Sep  2 20:43:47.648: IP: s=192.168.255.2 (GigabitEthernet0/0.50), d=192.168.8.7, len 544, input feature
    *Sep  2 20:43:47.648:     UDP src=3078, dst=1204, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:47.648:     UDP src=3078, dst=1204, Stateful Inspection(7), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:47.648:     UDP src=3078, dst=1204, MCI Check(101), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:47.648: IP: tableid=0, s=192.168.255.2 (GigabitEthernet0/0.50), d=192.168.8.7 (GigabitEthernet0/1.10), routed via RIB
    *Sep  2 20:43:47.648: IP: s=192.168.255.2 (GigabitEthernet0/0.50), d=192.168.8.7 (GigabitEthernet0/1.10), g=192.168.8.7, len 544, forward
    *Sep  2 20:43:47.652: IP: s=192.168.255.2 (GigabitEthernet0/0.50), d=192.168.8.7 (GigabitEthernet0/1.10), len 544, sending full packet
    *Sep  2 20:43:47.652:     UDP src=3078, dst=1204
    *Sep  2 20:43:47.676: IP: s=192.168.8.7 (GigabitEthernet0/1.10), d=192.168.255.2, len 32, input feature
    *Sep  2 20:43:47.676:     UDP src=1204, dst=3078, MCI Check(101), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:47.676: IP: tableid=0, s=192.168.8.7 (GigabitEthernet0/1.10), d=192.168.255.2 (GigabitEthernet0/0.50), routed via RIB
    *Sep  2 20:43:47.676: IP: s=192.168.8.7 (GigabitEthernet0/1.10), d=192.168.255.2 (GigabitEthernet0/0.50), len 32, output feature
    *Sep  2 20:43:47.676:     UDP src=1204, dst=3078, Common Flow Table(28), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:47.676:     UDP src=1204, dst=3078, Stateful Inspection(29), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:47.676:     UDP src=1204, dst=3078, CCE Post NAT Classification(41), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:47.676:     UDP src=1204, dst=3078, QoS Marking(68), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:47.676: IP: s=192.168.8.7 (GigabitEthernet0/1.10), d=192.168.255.2 (GigabitEthernet0/0.50), g=10.250.80.66, len 32, forward
    *Sep  2 20:43:47.676: IP: s=192.168.8.7 (GigabitEthernet0/1.10), d=192.168.255.2 (GigabitEthernet0/0.50), len 32, sending full packet
    *Sep  2 20:43:47.932: IP: s=192.168.255.2 (GigabitEthernet0/0.50), d=192.168.8.7, len 544, input feature
    *Sep  2 20:43:47.932:     UDP src=3078, dst=1204, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:47.932:     UDP src=3078, dst=1204, Stateful Inspection(7), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:47.932:     UDP src=3078, dst=1204, MCI Check(101), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:47.932: IP: tableid=0, s=192.168.255.2 (GigabitEthernet0/0.50), d=192.168.8.7 (GigabitEthernet0/1.10), routed via RIB
    *Sep  2 20:43:47.932: IP: s=192.168.255.2 (GigabitEthernet0/0.50), d=192.168.8.7 (GigabitEthernet0/1.10), g=192.168.8.7, len 544, forward
    *Sep  2 20:43:47.932: IP: s=192.168.255.2 (GigabitEthernet0/0.50), d=192.168.8.7 (GigabitEthernet0/1.10), len 544, sending full packet
    *Sep  2 20:43:47.944: IP: s=192.168.8.7 (GigabitEthernet0/1.10), d=192.168.255.2, len 32, input feature
    *Sep  2 20:43:47.944:     UDP src=1204, dst=3078, MCI Check(101), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:47.944: IP: tableid=0, s=192.168.8.7 (GigabitEthernet0/1.10), d=192.168.255.2 (GigabitEthernet0/0.50), routed via RIB
    *Sep  2 20:43:47.944: IP: s=192.168.8.7 (GigabitEthernet0/1.10), d=192.168.255.2 (GigabitEthernet0/0.50), len 32, output feature
    *Sep  2 20:43:47.944:     UDP src=1204, dst=3078, Common Flow Table(28), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:47.944:     UDP src=1204, dst=3078, Stateful Inspection(29), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:47.944:     UDP src=1204, dst=3078, CCE Post NAT Classification(41), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:47.944:     UDP src=1204, dst=3078, QoS Marking(68), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:47.944: IP: s=192.168.8.7 (GigabitEthernet0/1.10), d=192.168.255.2 (GigabitEthernet0/0.50), g=10.250.80.66, len 32, forward
    *Sep  2 20:43:47.944: IP: s=192.168.8.7 (GigabitEthernet0/1.10), d=192.168.255.2 (GigabitEthernet0/0.50), len 32, sending full packet
    *Sep  2 20:43:48.724: IP: s=192.168.255.2 (GigabitEthernet0/0.50), d=192.168.8.7, len 544, input feature
    *Sep  2 20:43:48.724:     UDP src=3078, dst=1204, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:48.724:     UDP src=3078, dst=1204, Stateful Inspection(7), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:48.724:     UDP src=3078, dst=1204, MCI Check(101), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Sep  2 20:43:48.728: IP: tableid=0, s=192.168.255.2 (GigabitEthernet0/0.50), d=192.168.8.7 (GigabitEthernet0/1.10), routed via RIB
    *Sep  2 20:43:48.728: IP: s=192.168.255.2 (GigabitEthernet0/0.50), d=192.168.8.7 (GigabitEthernet0/1.10), g=192.168.8.7, len 544, forward
  • 4.  RE: AP not up in remote site(MPLS)
    Posted Sep 02, 2014 07:17 PM
    Campus APs being deployed as Campus APs
    We have MPLS network.
    Campus APs running at other sites without issues.
    This is a new site.
    Here is the i/p of packet capture from switch.
    192.168.8.7    - AP
  • 5.  RE: AP not up in remote site(MPLS)
    Posted Sep 02, 2014 07:19 PM
    This is a new site.
    192.168.8.7    - AP
    .........................(trimmed)
  • 6.  RE: AP not up in remote site(MPLS)
    Posted Sep 02, 2014 07:20 PM
    APs are configured with
    1. static ip and subnet
    2. masterip
    3. serverip
  • 7.  RE: AP not up in remote site(MPLS)
    Posted Sep 02, 2014 07:23 PM
    Are you able to ping the controller from AP console ? Or can you ping the AP from the controller ?
    Do see any anything in the show log system all | include <AP mac=""></AP>
    Do you have cpsec enabled?
  • 8.  RE: AP not up in remote site(MPLS)
    Posted Sep 02, 2014 07:29 PM
    Yes I am able to ping the controller from AP console >>>apboot.
    I get a message that "success, host is alive" when i ping
    show datapath session table | include <ip of AP> shows pretty much the same o/p as posted only not so long.
    However, i havent checked the logs. will have them checked probably in the morning tomorrow.
    The console shows #######T#######T#######T## about 10 minutes and then proceedes till running ADP...  and then process is killed and it reboots. same thing happens
  • 9.  RE: AP not up in remote site(MPLS)
    Posted Sep 02, 2014 07:31 PM
    You also consider increasing the bootstrap threshold in the ap system profile if the delay is too big
  • 10.  RE: AP not up in remote site(MPLS)
    Posted Sep 02, 2014 07:33 PM
    yes.. But the AP is not displayed in show ap database at all!!
  • 11.  RE: AP not up in remote site(MPLS)
    Posted Sep 02, 2014 07:34 PM
    The AP is whitelisted so not to worry of cpsec
  • 12.  RE: AP not up in remote site(MPLS)
    Posted Sep 02, 2014 07:37 PM
    There are two of them with the same issue at the same site. while other sites are ok.\
    vlan internal allocation policy ascending
    vlan 10
    name DATA
    vlan 200
    name VOICE
    AP is in VLAN 10 access
