AP not working when Mobility controller is rebooted
  • 1.  AP not working when Mobility controller is rebooted
    Posted Aug 14, 2012 09:36 AM
    Hello every one,
    I have a 3200 with some AP-105 (which are all running in bridge mode).
    My problem is that when the AP(s) loose connection to the 3200 - they stop working after 30 sec (way less than the time it takes for the 3200 to reboot).
    Is there a way to increase this timeour (or disable it) ?
    Thank you.
    Br
    Jørgen
    #3200
  • 2.  RE: AP not working when Mobility controller is rebooted
    Posted Aug 14, 2012 11:00 AM
    You need to convert that AP to a Remote AP, and then choose the Remote AP Mode in the Virtual AP to Permanent.
  • 3.  RE: AP not working when Mobility controller is rebooted
    Posted Aug 14, 2012 02:07 PM
    Hi cjoseph,
    Would that just be one of my AP's ?
    I've just tried to provision it into a RAP but it seems to be staying down (at least from the Mobility controller view point).
    Is the purpose of this to turn one of the AP's into a kind of a local controller ?
    Thanks for the help
    Jørgen
  • 4.  RE: AP not working when Mobility controller is rebooted
    Posted Aug 15, 2012 06:59 AM
    Hi cjoseph,
    So. I tried to convert one of my AP's into a RAP unit. Seems to work just fine when the 3200 is reachable, BUT ....
    If I reboot the 3200 (or lose connection to it from the RAP) - then it still stopps to process the traffic (however it does seems like it holds out a bit longer - seems to be somewhere around 90 sec).
    Is there a way to increase this threshold so my wifi clients doesn get their traffic dropped if I reboot the 3200 ?
    Br
    Jørgen
  • 5.  RE: AP not working when Mobility controller is rebooted
    Posted Aug 21, 2012 01:10 AM
    A bit more jumping on this and it finally worked.
    Kudos to cjoseph - now running RAP mode and continues to work even if controller is down
  • 6.  RE: AP not working when Mobility controller is rebooted
    Posted Aug 21, 2012 06:51 AM
    excellent!
