last person joined: 5 hours ago
AP powers with injector but not from controller
  • 1.  AP powers with injector but not from controller
    Posted Dec 11, 2013 03:34 PM
    I have an AP93 that will not power up via a controller.  It powers up fine when using a power injector (3001GC), but nothing from a controller (620).  Have tried multiple cables and all of the PoE ports on the controller.  Other APs work fine on the controller.
    Is there any way to troubleshoot this issue, or do I need to just file a warranty claim?
  • 2.  RE: AP powers with injector but not from controller
    Posted Dec 11, 2013 04:22 PM
    Does the controller have POE licenses installed?  They might have been wiped out...  You can go to the licensing site to retrieve them if that is the case.
  • 3.  RE: AP powers with injector but not from controller
    Posted Dec 11, 2013 06:55 PM
    Yes, controllers have the PoE licenses installed.  I shipped out a replacement AP to the site and it worked fine.
    This particular AP had been replaced as possibly defective - not sure of the details other than it was replaced when we did a coverage upgrade, and was sitting in a box.  I pulled it out to test and it powered up and provisioned fine, but of course I was using a PoE injector.
    As we depleted our inventory, I once again pulled it out to test and eventually shipped it out.
    I've now tested it on 2 different controllers (620 w/ 6.1.3.10) and it doesn't power up.   Seems strange that it works with PoE injector, but not via PoE ports on controller.  I assumed the controller ports put out the same voltage.
