Hey, I've had a look and can't see anything obvious. Two things however you could investigate, it seems there is some crash informaiton available. Are you able to provide this?
Crash Information
Crash information is available; use 'show ap debug crash-info' to retrieve
Secondonly, it is possible the logs prior to the warm reset are being overwritten then the warm reset occurs. I can see that there is no syslog configured to capture these logs. Are you able to configure a syslog and then provide any logs once the next-warm reset has occured?
