AP rebooting again and again
  • 1.  AP rebooting again and again
    Posted Apr 03, 2014 05:19 AM
    One of our AP is rebooting again and again. In the logs I get following error:
    Reboot Reason: Reboot caused by kernel page fault at virtual address 00000010, epc == 00000010, ra == c06b32a4
    Our controller is 3400 and running OS 6.1.3.12. AP is 105.
    What is causing it?
    Farzan
    #3400
  • 2.  RE: AP rebooting again and again
    Posted Apr 03, 2014 05:27 AM
    You need to open a case with TAC.  Only they can understand that error message and fix it.
  • 3.  RE: AP rebooting again and again
    Posted Apr 03, 2014 10:09 AM
    On the boot try doing
    clear os
    purgeenv
    saveenv
    reset
    And reconfigure the ap again.   And see if that happens
    The tac will ask you to do that... So if it doesnt work  you can tell them i already did clear os and purgeenv.
    If it keep telling you the same error they will likely change the AP if its faulty.
    Cheers
    Carlos
  • 4.  RE: AP rebooting again and again
    Posted Apr 03, 2014 05:52 PM
    Yes it is happening still after performing the steps you have mentioned. I am opening a case with TAC.
  • 5.  RE: AP rebooting again and again
    Posted Jul 30, 2017 08:49 PM
    I had the same problema with IAP-103 using the virtual controller:
    Reboot Time and Cause: Reboot caused by kernel page fault at virtual address 003a0000, epc == c0354158, ra == c0354160
    I opened any tickets support on Aruba but at the moment no solution about this.
    Aruba's engeniers change my hardoware but the problem wasn't resolved.
  • 6.  RE: AP rebooting again and again
    Posted Dec 07, 2017 03:55 AM
    Hi All,
    It's likely similar with my case.  I have1 IAP 215 (Master) and 8 103 IAP Instant. Firmware version - Version 6.5.4.3
    virtual address 27bd00a4, epc == 801c5ca0, ra == c03a5c44
    It's rebooting every 6 hours sometimes 1 hour.
    Was this resolved?
  • 7.  RE: AP rebooting again and again
    Posted Dec 07, 2017 09:37 AM
    Same here.
    Have several 115s which are constantly rebooting with random intervals - from 6 hours at night up to every 15 minutes
    Reboot Time and Cause: Reboot caused by kernel page fault at virtual address 45f4c1ba, epc == 801c5ca0, ra == c040ec44
    Reboot Time and Cause: Reboot caused by kernel page fault at virtual address 00f40005, epc == 801c5ca0, ra == c040ec44
    Reboot Time and Cause: Reboot caused by kernel page fault at virtual address eaf6ead4, epc == 801c5ca0, ra == c040ec44
    Reboot alerts:
    07.12.2017 13:03
    07.12.2017 13:07
    07.12.2017 13:08
    07.12.2017 13:13
    07.12.2017 13:19
    07.12.2017 13:21
    07.12.2017 13:23
    07.12.2017 13:29
    07.12.2017 13:43
    07.12.2017 15:27
    07.12.2017 15:32
    07.12.2017 15:42
    07.12.2017 15:46
    07.12.2017 15:47
    07.12.2017 15:51
    07.12.2017 15:57
    07.12.2017 15:59
  • 8.  RE: AP rebooting again and again
    Posted Dec 07, 2017 09:44 PM
    you are both very likely hitting a s/w bug, raise a tac case, resist the urge (requests) to replace hardware for no justified reason. Same thing for purging the ap, that is not a solution for a s/w issue.
