AP rebooting daily
  • 1.  AP rebooting daily
    Posted Sep 08, 2021 02:21 PM
    Hi guys,
    I have a ~70 AP225 connecting to aruba 7200 and one of them has been going offline consistently every other day for the past month or so.  When I look at the AP LEDs it is blinking green and blinking amber.  I look at the HP switch it's connected to and the light is amber indicating 100mb.  To fix it I've been unplugging it from the switch port and plugging it back in.  Once I do this it finds the controller and is good for a day or two.
    When I look at Diagnostics > Access Points > Technical Support the log shows the below:
    Rebootstraps and Control Messages Log
    Recent Messages            Time now: Wed Sep  8 10:09:24 2021
    Time Offset                Message details
    -219                       RCVD: STATUS_REPORT len=52 peer=10.36.2.28 seq_num=3 rtt=0 result=OK
    -224                       SENT: ESSID_LIST len=565 peer=10.36.2.28 seq_num=5 tries=1 rtt=0 result=OK
    -224                       SENT: MONITORING_MSG_CONFIG len=139 peer=10.36.2.28 seq_num=4 tries=1 rtt=0 result=OK
    Rebootstrap                Wed Sep  8 10:05:18 2021
    -0                         RCVD: HELLO len=1234 peer=10.36.2.28 seq_num=0 rtt=0 result=OK
    -4095                      RCVD: BW_REPORT len=15 peer=10.36.2.28 seq_num=16 rtt=0 result=OK
    -4097                      RCVD: BW_REPORT len=37 peer=10.36.2.28 seq_num=15 rtt=0 result=OK
    Rebootstrap                Wed Sep  8 08:31:56 2021
    -403                       RCVD: STATUS_REPORT len=52 peer=10.36.2.28 seq_num=3 rtt=0 result=OK
    -408                       SENT: ESSID_LIST len=565 peer=10.36.2.28 seq_num=5 tries=1 rtt=0 result=OK
    Rebootstrap                Wed Sep  8 08:24:46 2021
    -8023                      RCVD: BW_REPORT len=15 peer=10.36.2.28 seq_num=6 rtt=0 result=OK
    -8029                      RCVD: BW_REPORT len=37 peer=10.36.2.28 seq_num=5 rtt=0 result=OK
    Info of last session
    Last heartbeat seq number  2005
    Reason for disconnect      Controller aged out
    Timestamp                  2021-09-08 08:58:51
    Has anyone seen this error message before "Controller aged out" and how you fixed it?
    Thanks!
    C
  • 2.  RE: AP rebooting daily
    Posted Sep 08, 2021 04:44 PM
    I would test the ethernet cable and the patch cable.
  • 3.  RE: AP rebooting daily
    Posted Sep 08, 2021 06:17 PM
    I was thinking the same thing.  If it is just one access point that consistently has this problem and none of the others do, it could very well be a problem with your physical connection.
  • 4.  RE: AP rebooting daily
    MVP EXPERT
    Posted Sep 09, 2021 01:12 PM
    Did you check the cable run and if there is enough PoE budget on your switch available?
    Marcel Koedijk | MVP Guru 2021 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opionions are my own
