last person joined: 2 hours ago
AP rebooting intermittently
  • 1.  AP rebooting intermittently
    Posted Oct 17, 2019 09:44 AM
    We have a small network using Aruba, 1x315, 3x305 that has worked fine for some time but over the last couple of days all the AP's have started to randomly reboot. In the report it says "LAST REBOOT REASON
    Preempted by provisioned master"
    Power is OK etc. What should I look for?
    The firmware is 8.5.0.0_70258 which was updated mid July
  • 2.  RE: AP rebooting intermittently
    MVP EXPERT
    Posted Oct 17, 2019 09:58 AM
    Do you have an IAP configured as a Preferred Master? If so has that IAP rebooted?
  • 3.  RE: AP rebooting intermittently
    Posted Oct 17, 2019 10:01 AM
    Yes the 315 is the master, it has rebooted with the other AP's but not all at the same time
  • 4.  RE: AP rebooting intermittently
    MVP EXPERT
    Posted Oct 17, 2019 10:15 AM
    Is the 315 a Preferred Master? Have you had any switch issues such a POE budgets? If you do a show version on the APs this will give you other clues as to why they rebooted.
  • 5.  RE: AP rebooting intermittently
    Posted Oct 17, 2019 10:30 AM
    There doesn't seem to be a power issue. It's not overloaded & it has worked for months before with no issue.
