ap-regroup provisioning fails
  • 1.  ap-regroup provisioning fails
    Posted Mar 24, 2017 10:54 AM
    Hi there,
    I am struggling with this problem for a while now.
    We have some IAP205 and 115. I converted them, so our 3400 Controller can manage them.
    The conversion works, the controller can adress the APs.
    I created a new AP-Group.
    Under "Configuration -> Wireless -> AP Installation" I provision them with the new AP-Group and click on "Apply and reboot".
    But after the reboot they are still in den "default" AP-group. I tried it with the wizard and on cli as well. Same results: Still default group.
    What are the reasons for this cause?
    best regards,
    mg
  • 2.  RE: ap-regroup provisioning fails
    Posted Mar 24, 2017 01:07 PM
    Are the APs in the Campus AP whitelist?
  • 3.  RE: ap-regroup provisioning fails
    Posted Mar 25, 2017 10:18 AM
    Yeah, they are whitelisted. But I found the Problem, why it was not working:
    The APs had spaces in their names. On Controller-CLI the DB clearence was also not possible. I had to reset the APs and Controller.
    After Setting names without a space, the provisioning worked instant after reboot.
    I'm asking myself why the controller even allows that.
  • 4.  RE: ap-regroup provisioning fails
    MVP EXPERT
    Posted Mar 25, 2017 10:53 AM
    Hey, you can clear AP's with spaces in their names using the "XXX" either side. This command works for any references which might have a space in them.
    e.g
    #clear gap-db "AP name"
    or
    #show wlan  virtual-ap "virtual ap"
