Ap rename and ap-group mchange
This thread has been viewed 30 times
  • 1.  Ap rename and ap-group mchange
    Posted Jun 15, 2021 02:42 PM
    I have a clluster of MC and one MM 8.6.08.
    CPsec is enable with autoprovisionning cert and from ip dhcp range trust.
    The first renaming of an AP and the ap-group change was OK.
    Now I can't change these value through the GUI. After completing the "provision" data, and submit, the AP doesn't reboot ....
    I tried different model of AP with same result, it's seems there's a bug or communication problem between the cluster and the APs.
    How can I solve this problem ? Thks for your help.
    Another question : is it possible to force an ARM scan (to load-balance immediately the AP on both controller, or to force a channel/power reaffectation)
    Cdlt.
    stephane henrot
  • 2.  RE: Ap rename and ap-group mchange
    Posted Jun 15, 2021 09:25 PM
    How do you know the AP is not rebooting?  Check to see if this is your issue https://community.arubanetworks.com/community-home/digestviewer/viewthread?GroupId=7&MessageKey=1ddf4b93-af14-4ff8-9719-60e56281307a&CommunityKey=867d34a4-1e6a-4b9a-9349-df7b4c84b3cb&tab=digestviewer&ReturnUrl=%2fbrowse%2fallrecentposts
    ArubaOS with an MM uses Airmatch, which only changes channels once per day by default at 5am.  You can force a recalculation by SSH into the MM and typing   "airmatch runnow full"
  • 3.  RE: Ap rename and ap-group mchange
    Posted Jun 16, 2021 01:05 PM
    HI,
    Thanks for your reply. It seems to be the "same" problem, i tried the process in the URL but I can't make a write erase ...
    What I can see it' the MM databse is OK but note the MCs. I will make more deeper test but for my customer it's clearly a bug.
    It's a convention center and the ap-group change frequently, so the GUI must be ok for him.
    Il will open a case if I don't find the reason of this behavior.
    I can see that the AP doesn't reboot on the switch (no up,down in log) and in Airwave.
    Regarding the ARM i will make a test
    Brgs
    stephane henrot
  • 4.  RE: Ap rename and ap-group mchange
    Posted Jun 16, 2021 03:10 PM
    Delete the AP from the CPSEC database and allow the AP to reboot and re-acquire the CPSEC entry.  After that, don't modify APS in the CPSEC database.
  • 5.  RE: Ap rename and ap-group mchange
    Posted Jun 22, 2021 05:50 AM
    Hi, I opened a Case and the support team confirm there's a pb with the GUI. Renaming an AP or changing the group doesn't work.
    The AP only switch MC and doesn't reboot. The workaround is to use CLI ap-regroup command.
    Il will update after resolution from TAC
    Brgds
    stephane henrot
  • 6.  RE: Ap rename and ap-group mchange
    Posted Jun 23, 2021 08:54 AM
    I too maintain a CPSEC whitelist, and would modify the  CPSEC entry for that device and perform a apboot.
    William Galway
