AP Role = Deny All?
  • 1.  AP Role = Deny All?
    Posted Apr 29, 2021 11:02 AM
    I found an old post from 2014 that shows this.
    Deny All role being assigned. Why? | Controllerless Networks (arubanetworks.com)
    It's now 2021 and i'm facing the same issue.
    I have some AP's being setup. I have the SSID broadcasting using WPA2-AES, it goes to a Radius server, which authenticates only if the laptop is part of the approved group AND it has the correct internal PKI cert.
    I can validate that the laptop connect, was assigned a correct DHCP address, and I can confirm that it was properly authenticated on the RADIUS/NPS server with a valid cert being presented.
    For some reason the AP role is listed as "Deny All"
    Anyone have any idea what and what that might happen?
    Matt
  • 2.  RE: AP Role = Deny All?
    Posted Apr 30, 2021 11:00 AM
    I have seen this a few times where the AP was unable to reach the authentication server. But best is to get the logs and analyze those or have them analyzed by Aruba TAC.
  • 3.  RE: AP Role = Deny All?
    Posted Apr 30, 2021 11:07 AM
    Sounds good :)
    The odd thing is that the laptops are able to successfully connect, which goes through the Radius/NPS server. And there is no error on connection.
    It seems to have "corrected it's self" for now, but if it comes back I'll open a ticket with TAC.
    Matt
