AP showing up without any flags
  • 1.  AP showing up without any flags
    Posted Oct 07, 2013 02:51 PM
    Why would any AP not have any flags under AP Installation?
  • 2.  RE: AP showing up without any flags
    Posted Oct 07, 2013 02:55 PM
    A regular campus AP will not show any flags unless :
    Is the AP up , are you having issues with the AP ?
  • 3.  RE: AP showing up without any flags
    Posted Oct 07, 2013 02:57 PM
    Up until about 3 hours ago, it was showing up with a flag of 2. Yes it has stopped broadcasting any SSID's. I cannot reprovision it either. I can ping the AP though.
  • 4.  RE: AP showing up without any flags
    Posted Oct 07, 2013 03:17 PM
    From the command line do the following : show ap database and also show log system all <ap mac address>
    Can you console into the AP ?
  • 5.  RE: AP showing up without any flags
    Posted Oct 07, 2013 03:30 PM
    (usext1wlsco01) #show ap database  | Include ussea
    ussea1wlsap01  NorthAmerica-Tier2-3-B  105      10.139.0.50    Up 27m:25s                64.90.226.168
    The show log system all <ap mac address> does not yield any information.
    I am not local to the site, so consoling in is not an option right now.
  • 6.  RE: AP showing up without any flags
    Posted Oct 07, 2013 03:38 PM
    This command will let you know what SSID is getting broadcast from that particular AP:
    (controller) #show  ap  bss-table ap-name <apname>
    Can you try pinging the AP from the controller ?
  • 7.  RE: AP showing up without any flags
    Posted Oct 07, 2013 03:40 PM
    It's not broadcasting any SSID's, even though it's in the correct AP Group.
  • 8.  RE: AP showing up without any flags
    Posted Oct 07, 2013 03:44 PM
    and yes I can ping the AP from the controller
    (usext1wlsco01) #ping 10.139.0.50
    Press 'q' to abort.
    Sending 5, 100-byte ICMP Echos to 10.139.0.50, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 154.319/166.817/182.186 ms
    (usext1wlsco01) #
  • 9.  RE: AP showing up without any flags
    Posted Oct 07, 2013 03:45 PM
    The 2 would indicate that you have CPsec enabled.  Is it enabled in this environment?  Do other APs have the 2 flag?
    If so, check your CPsec whitelist to see if this AP is listed properly.
  • 10.  RE: AP showing up without any flags
    Posted Oct 09, 2013 04:17 AM
    This AP is visible in AP installation page of controller??
    Use show ap config ap-name <ap-name> to verify its configuration.
  • 11.  RE: AP showing up without any flags
    Posted Oct 29, 2013 05:15 PM
    Hi.
    Did you by any chance change the regulatory domain? (even if you are not getting a reg domain mismatch flag)
