AP stuck in approved-ready-for-cert
  • 1.  AP stuck in approved-ready-for-cert
    Posted Jul 12, 2018 07:15 AM
    A customer tried installing a new AP and it gets stuck in "approved-ready-for-cert" for some reason. Auto Cert is enabled for all networks
    #show control-plane-security
    Control Plane Security Profile
    Parameter Value
    Control Plane Security Enabled
    Auto Cert Provisioning Enabled
    Auto Cert Allow All Enabled
    Auto Cert Allowed Addresses N/A
    I tried removing it from the whitelist but it just comes back in the same state.
    I tried manually setting state certified-factory-cert but ut ended up in certified-hold-factory-cert
    They tried a different switchport and a different AP on the same switchport aswell but it didn't help.
    There is a FW between the AP and controller but we have verified that there are no blocks.
    show tpm cert-info shows a generated factory certificate that expires in 2032.
    The log is spitting out this error:
    Jul 12 09:55:03  stm[3951]: <305049> <WARN> |stm|  Unsecure AP xxxxxxxxxx has been denied access because Control Plane Security is enabled and the AP is not approved.
    Anyone got an idea what might be wrong?
    /Johan
  • 2.  RE: AP stuck in approved-ready-for-cert
    Posted Jul 12, 2018 04:54 PM
    Can you elaborate on this point?
    Was the test AP able to get certified-factory-cert in the Whitelist?
  • 3.  RE: AP stuck in approved-ready-for-cert
    Posted Jul 13, 2018 04:54 AM
    @BBrylski
    They other AP that was tested got the same issue.
  • 4.  RE: AP stuck in approved-ready-for-cert
    Posted Jul 12, 2018 05:06 PM
    Hi Johan,
    A few questions.
    Which software version?
    Which controllers type?
    Which AP model?
    What is the connection between the controller and the new AP? High latency?
    Here is a link about CPSEC: https://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/Control_Plane/Whitelists_on_Campus_and_Remote_APs.htm%3FTocPath%3DControl%2520Plane%2520Security%7C_____3
    From the link :
    certified-hold-factory-cert: The campus AP is certified with a factory certificate but requests to be certified again. Such APs are not approved as secure until you manually change the status and verify that it is not compromised.
    NOTE: If an AP is in this state due to connectivity problems, then the AP recovers and leaves this hold state as soon as connectivity is restored.
    So check at least for connectivity issues between the controller and the AP.
  • 5.  RE: AP stuck in approved-ready-for-cert
    Posted Jul 13, 2018 05:21 AM
    6.4.4.16
    7210
    Which AP model?
    225
    around 1.4ms from the controller to the AP. There are about 150 APs at the same location and 10 with the same AP-group. 4-5 APs on the same subnet.
    I tried manually setting the state certified-factory-cert but it reverts back to certified-hold-factory-cert after a minute or so.
    /Johan
  • 6.  RE: AP stuck in approved-ready-for-cert
    Posted Jul 13, 2018 07:43 AM
    Found the problem!
    The FW team only checked the FW openings from the AP to the controller.. and it  turned out a recent change in the FW closed UDP 8211 from the controller to the AP.
    So APs that were already up and certified worked but a new AP that needed to be certified failed.
    Thanks for your help.
    /Johan
