ap summary per local
  • 1.  ap summary per local
    Posted Oct 24, 2016 02:56 PM
    Is there a command to view the number of active APs per controller?
    show ap database-summary only gives me a total number.
  • 2.  RE: ap summary per local
    Posted Oct 24, 2016 03:48 PM
    Give this a shot.
    (Lab_Master_7024) #show ap database switch <IPADDRESS>
  • 3.  RE: ap summary per local
    Posted Oct 27, 2016 03:30 PM
    ya, i've used that before.  show ap database switch "ip" | include Total gives me what i'm looking for with a little more typing. It would be a pain if I had more than 4 controllers...
  • 4.  RE: ap summary per local
    Posted Oct 28, 2016 12:29 PM
    Not sure what you mean by 'active' as looking at the database totals also includes APs that are down.
    show license-usage ap
    is another way to see how many APs are up that is a bit less stress on the fingers/keyboard.
  • 5.  RE: ap summary per local
    Posted Oct 28, 2016 03:11 PM
    I have 2 HA pair setup and one pair is having an issue with LACP timeouts. When they timeout, the APs move over to the secondary controller.
    I want to see how many "up" APs are currently assiciated to each controller without looking at a list and counting them manually.
  • 6.  RE: ap summary per local
    Posted Oct 28, 2016 10:25 PM
    Ah ok, maybe this then:
    show ap active | include Num
    and possibly helpful as well
    show ap standby | include Num
