AP was visible under default group but not anymore after Appy and Reboot under AP Installation
  • 1.  AP was visible under default group but not anymore after Appy and Reboot under AP Installation
    Posted Sep 25, 2017 08:01 PM
    The default Master Discovery method under AP Installtion is using Host Controller Name of aruba-master.   If the AP is located in different VLAN from the controller, and aruba-master DNS entry does not exist in internal DNS or DHCP option 43 pointing to master controller IP is not configured in DHCP server, change the Master Dicovery method to Master Controller IP/DNS Name method, and enter controller IP in this field.  All these settings can be found under Configuration - AP Installation - pick an AP - Provision.
    The AP will need to be factory defaulted, then show up under Configuration - AP Installation in GUI or show ap database in CLI under default AP group.  It is then ready to be provisioned to the correct AP group by following the first paragraph above.
  • 2.  RE: AP was visible under default group but not anymore after Appy and Reboot under AP Installation
    Posted Sep 25, 2017 10:17 PM
    If you provision with all of the defaults, it will first:
    1 - Check to find the controller via multicast on the same subnet
    2 - Check to find the DHCP options 43 and 60
    3 - Attempt to resolve aruba-master.<domain suffix from dhcp>.com
    You do not have to edit anything for it to use those discovery methods above.
  • 3.  RE: AP was visible under default group but not anymore after Appy and Reboot under AP Installation
    Posted Sep 25, 2017 10:22 PM
    The original post is applicable if the AP does not reside in the same subnet as the controller and there is no aruba-master DNS entry and there is no DHCP option configured.
