last person joined: 10 hours ago
AP Wizard goof -- used automatic discovery instead of manual
  • 1.  AP Wizard goof -- used automatic discovery instead of manual
    Posted Apr 10, 2012 05:41 PM
    I re-provisioned 81 air-monitors in distant locations this afternoon.
    I hadn't realized that "automatic" meant ADP only -- I was thinking it meant "like default" which uses aruba-master after ADP fails.
    So now that I have all of them effectively isolated, has anybody had any luck tricking the discovery protocol into working over the WAN? or will I have to dispatch a technician to every store to manually correct them all?
    --Matthew
  • 2.  RE: AP Wizard goof -- used automatic discovery instead of manual
    Posted Apr 10, 2012 05:44 PM
    --Matthew
    Since the APs reboot every few minutes, you could try configuring DHCP opton 43 and 60 at that site....
  • 3.  RE: AP Wizard goof -- used automatic discovery instead of manual
    Posted Apr 10, 2012 05:57 PM
    All of them are statically assigned IP addresses, gateway, netmast and DNS servers -- no DHCP in their VLAN.
    They had been looking up aruba-master and connecting, now they broadcast on port 8200 and reboot and keep broadcasting...
    sigh.
  • 4.  RE: AP Wizard goof -- used automatic discovery instead of manual
    Posted Apr 10, 2012 06:05 PM
    Okay.  Advice, hail mary edition:
    If you have a Cisco layer3 switch at that location with the APs, you can configure an ip helper-address to point to the ip address of the controller on the ip interface:
    config t
    interface vlan 11
    ip helper-address <ip address of Aruba Controller>
    In addition, you would also have to configure the switch to forward port 8200:
    config t
    ip forward-protocol udp 8200
    Good luck... :(
  • 5.  RE: AP Wizard goof -- used automatic discovery instead of manual
    Posted Apr 10, 2012 07:38 PM
    We're using Adtran 1335 layer2/3 switches, but the command structure is similar.
    I've broken an AP in the lab to match the 81 production APs and this helper-sleight-of-hand works!
    No to test it on a few live sites...
    Thanks for the tip.  I was starting to try to do the same thing trough policy-based-routes.  The helper-address is much simpler.
    I'll let you know how the live sites go when I come up for air.
    --Matthew
  • 6.  RE: AP Wizard goof -- used automatic discovery instead of manual
    Posted Apr 10, 2012 10:40 PM
    It worked like a charm, then using the wizard to specify hostname brok them again.
    Turns out manually re-provisioning works every time, the wizard breaks something -- but not for all access points. Two of them came back on the second "correct" wizard run.
    I'll re-fix them all and re-re-provision them manually and get this behind me.
    Thanks again!
  • 7.  RE: AP Wizard goof -- used automatic discovery instead of manual
    Posted Apr 10, 2012 10:43 PM
    Can you try AP installation instead of the wizard to provsion your APs?
  • 8.  RE: AP Wizard goof -- used automatic discovery instead of manual
    Posted Apr 11, 2012 11:44 AM
    That works fine, I was trying to go for the least-work ;)
