AP won't join cluster
This thread has been viewed 24 times
  • 1.  AP won't join cluster
    Posted Feb 21, 2021 03:09 PM
    Hi, I have a cluster of IAP207 AP's and I am trying to Add a IAP 325 to the cluster. They are all US ap's. When I add the 325 I get the error"AP register fail because of regulatory domain mismatch" but the ap is a us model. Everything is running the same AOS. What should I do? Thanks,
    Jack Sommers
  • 2.  RE: AP won't join cluster
    Posted Mar 04, 2021 06:48 AM
    Call TAC if that's a 100% accurate description of what's happening.
    James Whitehead
