AP won't License
  • 1.  AP won't License
    Posted Apr 27, 2012 04:04 PM
    I am having a problem adding an AP to a 3600 controller running 6.1.3.0 software.
    I connected a new AP to the network and it shows up on the controller with a IL flags (Inactive and unlicensed)
    There are 24 unused licenses on the controller. (See screenshots)
    I've tried a couple different new AP's but they all show up the same way.
    Control plane security is off.
    I've rebooted the controller as well.... no luck.
    Any ideas????
    #3600
  • 2.  RE: AP won't License
    Posted Apr 27, 2012 04:12 PM
    Can't tell from your limited screen shot if you have other feature licenses on the same controller.
    For instance, do you have PEF/PEFNG and/or WIP/RFP licenses as well ?
    If you do, are they quantity = 128 or quantity = 152 ?
    JF
  • 3.  RE: AP won't License
    Posted Apr 27, 2012 04:18 PM
    (Master_Aruba3600-US) #show ap license-usage
    Total AP Licenses                       : 152
    Remote-Node AP Licenses Used            : 0
    AP Licenses Used                        : 128
     Tunneled Node Licenses Used                     : 0
    Unused AP Licenses                      : 24
    Licenses used for Campus AP's           : 128
    Available Campus AP's                   : 0
    Licenses used for Remote AP's           : 0
    Available Remote AP's                   : 0
    Total Ortronics AP Licenses             : 0
    Ortronics AP Licenses Used              : 0
    Total Indoor Mesh AP's Supported        : 512
     Indoor Mesh AP's Active                 : 0
    Total Outdoor Mesh AP's supported       : 512
    Outdoor Mesh AP's Active                : 0
    Total PEF Licenses                      : 152
    Remote-Node PEF Licenses Used           : 0
    PEF Licenses Used                       : 128
    Total 802.11n-120abg Licenses   : 0
     802.11n-120abg Licenses Used    : 0
    Total 802.11n-121abg Licenses   : 0
    802.11n-121abg Licenses Used    : 0
    Total 802.11n-124abg Licenses   : 0
    802.11n-124abg Licenses Used    : 0
    Total 802.11n-125abg Licenses   : 0
    802.11n-125abg Licenses Used    : 0
  • 4.  RE: AP won't License
    Posted Apr 27, 2012 04:28 PM
    A 3600 will only support 128 Campus APs.  Aruba allows more AP licenses because a 3600 can support up to 512 remote APs (RAPs).
    If these are all in Campus AP (CAP) mode, you have hit the limit of the 3600.
  • 5.  RE: AP won't License
    Posted Apr 27, 2012 04:31 PM
    Wow.... i should have known that. It must be a Friday.... time to go home I think.
  • 6.  RE: AP won't License
    Posted Apr 28, 2012 11:13 AM
    Friday is good :)
    WIth the full snapshot of the licensing output it can been seen that you have all APs in campus mode.
    Notice the 'number of remote APs available: 0' output...   zero is zero ;)
