AP won´t show at controller
  • 1.  AP won´t show at controller
    Posted Mar 18, 2019 05:45 AM
    Hey,
    i have the following problem:
    I have an 345 which wants correctly connect to our MM.
    set device anul0 mtu to 2000
    Starting watchdog process...
    Aruba watchdog daemon started [1 thread(s)]
    LLDP not sent yet, DHCP is waiting
    Starting DHCP
    net.ipv4.conf.all.arp_notify = 1
    Getting an IP address...
    [   28.001000] device eth0 entered promiscuous mode
    net.ipv4.conf.all.arp_notify = 0
    net.ipv4.conf.br0.arp_notify = 1
    x.x.x.x 255.255.252.0 x.x.x.x
    Running ADP...Done. Master is x.x.x.x
    [   43.720909] wl 0000:01:00.0: enabling device (0000 -> 0002)
    [   43.823111] wifi0: AP type AP-345, radio 0, max_bssids 16
    [   44.174786] usbcore: registered new interface driver usbserial
    [   44.237540] usbcore: registered new interface driver usbserial_generic
    [   44.315785] usbserial: USB Serial support registered for generic
    [   44.393424] usbcore: registered new interface driver cp210x
    [   44.454549] usbserial: USB Serial support registered for cp210x
    AP Reboot reason:  Power-reset
    shutting down watchdog process (nanny will restart it)...
            <<<<<       Welcome to the Access Point     >>>>>
    I checked the Master IP, it is correct and worked for many other APs before.
    At our controller i checked the whitelist entry for this AP:
    (xxx) *#show whitelist-db cpsec mac-address 90:4C:81:C0:75:EE
    Control-Plane Security Whitelist-entry Details
    MAC-Address        AP-Group  AP-Name  Enable   State                   Cert-Type     Description  Revoke Text  Last Updated
    90:4c:81:c0:75:ee                     Enabled  certified-factory-cert  factory-cert                            Thu Feb 28 15:39:22 2019
    Total Entries: 1
    I tried to take the AP only today, but it won´t show at our MM. How can i verify, what is causing the problems? We also tried factory resetting the AP.
    Thanks in advance and kind regards
    Daniel
  • 2.  RE: AP won´t show at controller
    MVP EXPERT
    Posted Mar 18, 2019 06:36 AM
    What version of code is running on your MD's, you will need a minimum of 8.3.0.0 for an AP345. Just a note, you should be pointing your APs to your MD's not the MM's since the MM's will not terminate an AP.
  • 3.  RE: AP won´t show at controller
    Posted Mar 18, 2019 06:37 AM
    Try typing "show ap database" at the MD that it connects to.  See if there are any flags.
  • 4.  RE: AP won´t show at controller
    Posted Mar 18, 2019 06:54 AM
    Hey,
    we are using version 8.4.0.0.
    Under sh ap database i see the following entry:
    NAPXXXX   XX    345     x.x.x.x   Down                2      x.x.x.x  0.0.0.0
  • 5.  RE: AP won´t show at controller
    Posted Mar 18, 2019 06:59 AM
    Does the ap-group have an AP system profile with an LMS-IP that redirects the access point to a controller that doesn't exist?
  • 6.  RE: AP won´t show at controller
    Posted Mar 18, 2019 07:03 AM
    The LMS-IP for the AP Group is correct. It is the vrrp adress for the MC Cluster. There are over 100 APs (345) in the same AP group and they are working just fine.
  • 7.  RE: AP won´t show at controller
    Posted Mar 18, 2019 07:12 AM
    If "show ap database" shows a controller ip address, I would SSH into that controller and type "show log system 50" and see if there is any reference to that access point.  After an AP discovers a cluster, it does not rely on dns/dhcp discovery anymore, it downloads the nodelist of the cluster and connects to one of the controllers in the cluster.  It would seem that controller does not have a standby ip address, which is interesting.
  • 8.  RE: AP won´t show at controller
    Posted Mar 18, 2019 07:18 AM
    I have found the following entries in the log, but under the MAC adress:
    Mar 18 12:05:05 :305061:  <4048> <WARN> |stm|  sapm_proc_hello_req: AP x.x.x.x 90:4c:81:c0:75:ee GSM CLUSTER_AAC is not copied to assigned A-AAC, ignore HELLO
    Mar 18 12:06:01 :305061:  <4048> <WARN> |stm|  sapm_proc_hello_req: AP x.x.x.x 90:4c:81:c0:75:ee GSM CLUSTER_AAC is not copied to assigned A-AAC, ignore HELLO
    Mar 18 12:07:06 :305061:  <4048> <WARN> |stm|  sapm_proc_hello_req: AP x.x.x.x 90:4c:81:c0:75:ee GSM CLUSTER_AAC is not copied to assigned A-AAC, ignore HELLO
    Mar 18 12:09:07 :305061:  <4048> <WARN> |stm|  sapm_proc_hello_req: AP x.x.x.x 90:4c:81:c0:75:ee GSM CLUSTER_AAC is not copied to assigned A-AAC, ignore HELLO
    Mar 18 12:09:56 :305061:  <4048> <WARN> |stm|  sapm_proc_hello_req: AP x.x.x.x 90:4c:81:c0:75:ee GSM CLUSTER_AAC is not copied to assigned A-AAC, ignore HELLO
    Mar 18 12:10:55 :305061:  <4048> <WARN> |stm|  sapm_proc_hello_req: AP x.x.x.x 90:4c:81:c0:75:ee GSM CLUSTER_AAC is not copied to assigned A-AAC, ignore HELLO
    Mar 18 12:13:10 :305061:  <4048> <WARN> |stm|  sapm_proc_hello_req: AP x.x.x.x 90:4c:81:c0:75:ee GSM CLUSTER_AAC is not copied to assigned A-AAC, ignore HELLO
    Mar 18 12:14:03 :305061:  <4048> <WARN> |stm|  sapm_proc_hello_req: AP x.x.x.x 90:4c:81:c0:75:ee GSM CLUSTER_AAC is not copied to assigned A-AAC, ignore HELLO
    Mar 18 12:15:16 :305061:  <4048> <WARN> |stm|  sapm_proc_hello_req: AP x.x.x.x 90:4c:81:c0:75:ee GSM CLUSTER_AAC is not copied to assigned A-AAC, ignore HELLO
    Mar 18 12:15:52 :305061:  <4048> <WARN> |stm|  sapm_proc_hello_req: AP x.x.x.x 90:4c:81:c0:75:ee GSM CLUSTER_AAC is not copied to assigned A-AAC, ignore HELLO
  • 9.  RE: AP won´t show at controller
    Posted Mar 18, 2019 07:39 AM
    That message is important.  How many controllers do you have an what models are they?
  • 10.  RE: AP won´t show at controller
    Posted Mar 19, 2019 06:57 AM
    We have two controllers for our group subset.
    Each controller has the following specs:
    ArubaOS (MODEL: Aruba7210), Version 8.4.0.0
    They are placed under LAN-Hardware in our MM Tree:
  • 11.  RE: AP won´t show at controller
    Posted Mar 19, 2019 07:44 AM
    Is that the only access point with that problem?
  • 12.  RE: AP won´t show at controller
    Posted Mar 19, 2019 08:02 AM
    No, i have looked after the warning and have found at least one more AP with the same errors on both controllers.
  • 13.  RE: AP won´t show at controller
    Posted Mar 20, 2019 10:16 AM
    Should i open a ticket or can anyone help me with my problems?
  • 14.  RE: AP won´t show at controller
    Posted Mar 20, 2019 11:16 AM
    Yes, if your issue is critical, a ticket with TAC should be created.
  • 15.  RE: AP won´t show at controller
    Posted Mar 20, 2019 12:12 PM
    Are the working and none working aps in the same subnet?
  • 16.  RE: AP won´t show at controller
    Posted Mar 21, 2019 03:18 AM
    (cluster1) *#show lc-cluster group-membership
    Cluster Enabled, Profile Name = "LC-LAN-Controller"
    Redundancy Mode On
    Active Client Rebalance Threshold = 50%
    Standby Client Rebalance Threshold = 75%
    Unbalance Threshold = 5%
    AP Load Balancing: Enabled
    Active AP Rebalance Threshold = 50%
    Active AP Unbalance Threshold = 5%
    Active AP Rebalance AP Count = 30
    Active AP Rebalance Timer = 1 minutes
    Cluster Info Table
    Type IPv4 Address    Priority Connection-Type STATUS
    self    x.x.x.x      	  128             N/A CONNECTED (Member)
    peer    y.y.y.y           128    L2-Connected CONNECTED (Leader, last HBT_RSP 82ms ago, RTD = 0.000 ms)
    (cluster2) *#show lc-cluster group-membership
    Redundancy Mode On
    Cluster Info Table
    peer    x.x.x.x           128    L2-Connected CONNECTED (Member, last HBT_RSP 67ms ago, RTD = 0.396 ms)
    self    y.y.y.y           128             N/A CONNECTED (Leader)
    Looks pretty normal to me.
    Yes, there are working and non-working APs in the same subnet.
  • 17.  RE: AP won´t show at controller
    Posted Apr 12, 2019 02:44 PM
    Did you find the solution?  I have the exact same problem. I have 6 controllers. All 7280s and have APs running on them with no problem. I get the following error?
    sapm_proc_hello_req: GSM CLUSTER_AAC is not copied to assigned A-AAC, ignore HELLO
    It seems my whitelist isn't being copied to all the controllers and the AP shows denied when I do a sh ap database long command
  • 18.  RE: AP won´t show at controller
    Posted Apr 15, 2019 04:31 AM
    i have opened a case with Aruba and send them the same logs and the answer was, that it seems like a hardware failure in the AP, so they had send me a spare AP.
  • 19.  RE: AP won´t show at controller
    Posted Apr 15, 2019 10:04 AM
    I'm sure that wasn't the problem. I noticed that the whitelist on my 6 controllers doesn't match. I added this entry to the MM and since all 6 controllers are part of a cluster they should sync up. We had a problem adding 4 controllers (7280s) to our exising cluster. The TAC solution was to delete the cluster and rebuild it with the new controllers added. I'm hoping that's no the solution this time. We currently have 2,000 APs running on 6.4 and migrated 1,000 over to 8.3.0.3 and are seeing these little bugs and are nervous about moving the remaining 2,000 this summer.
  • 20.  RE: AP won´t show at controller
    Posted Apr 15, 2019 10:21 AM
    8.3.0.3 is older and many fixes have been put into 8.3.0.6 which is the current version.  After a bug scrub, I would plan to move to that as soon as possible this summer before migrating access points.
  • 21.  RE: AP won´t show at controller
    Posted Apr 19, 2019 09:22 AM
    I discovered my problem. I was hard coding the SETENV master on the AP to the MM and no the VRRP IP address. This is why my whitelists weren't syncing the entry correctly. Can't wait until all of the campus is migrated over to 8.3 from 6.4 so the APs will find the information dynamically.
  • 22.  RE: AP won´t show at controller
    Posted Mar 20, 2019 11:21 AM
    How does the cluster look when you use the command "show lc-cluster group-membership" from both of the 7210 mds? Do they show as L2 connected, or something else?
