AP103 For Wall Mount
  • 1.  AP103 For Wall Mount
    Posted Nov 21, 2014 03:12 AM
    We have WIFI project  & Survey showed that we need some APs to be wall mounted
    we want to use AP-103 to save cost & because areas are low density ... but found that inside AP103 datasheet it is written that  "  Built-in antennas are optimized for horizontal ceiling
    mounted orientation of the AP."
    Does this mean that AP103 is not good for wall mount  & using AP-103H is a must ?
  • 2.  RE: AP103 For Wall Mount
    Posted Nov 21, 2014 03:47 AM
    Correct. You can also use an L bracket to mount the 103 on the wall.
  • 3.  RE: AP103 For Wall Mount
    Posted Nov 22, 2014 06:04 PM
    What is Correct  :D  ?
    if AP103 can be mounted on wall ... will it be fine @ Coverage ?
  • 4.  RE: AP103 For Wall Mount
    Posted Nov 22, 2014 06:10 PM
    You should make every attempt to mount it horizontally. You can use an L bracket to mount it horizontally on a wall.
  • 5.  RE: AP103 For Wall Mount
    Posted Nov 28, 2014 05:56 AM
    What is this L Bracket ?
    What is the part number
  • 6.  RE: AP103 For Wall Mount
    Posted Nov 28, 2014 09:00 AM
    Home Depot or Lowes ;-)
