AP105 and Juniper NAC Integration
  • 1.  AP105 and Juniper NAC Integration
    Posted Sep 20, 2012 11:32 AM
    Hello All,
    Does anyone have any experience with Aruba AP105's integrating with Juniper Network Access Control appliances?  Basically when plugging in the Aruba AP105 into our access switch we would like it to be recognized by the Juniper NAC appliance and the Juniper NAC appliance to flip the access switchport to the appropriate VLAN.  Is this possible and if so how do we go about getting the AP105 being recognized by the Juniper NAC - is it via a certificate?  Once the Juniper NAC flips the AP105 to the appropriate VLAN the AP will then get an IP address that will allow it to call home to the controller.  Any suggestions?
    Cheers,
    Brian
  • 2.  RE: AP105 and Juniper NAC Integration
    Posted Sep 20, 2012 12:20 PM
    You probably have to contact Juniper to see what your options are with their NAC appliance..
  • 3.  RE: AP105 and Juniper NAC Integration
    Posted Sep 20, 2012 12:32 PM
    OK, I will check with Juniper.  But do you know if these scenarios are possible with the 105's regardless of the vendor?
  • 4.  RE: AP105 and Juniper NAC Integration
    Posted Sep 20, 2012 08:36 PM
    You need to speak to Juniper about their capabilities.
