AP105 issue fixed by AP reboot
  • 1.  AP105 issue fixed by AP reboot
    Posted Mar 22, 2012 12:03 AM
    Dear expert
    The several users informed voice quality was very bad and noisy under the certain access points from one day ago suddenly. The claim was fixed by three  APs reboot around there. Do you have any idea what was happening in the APs in such a case and how to find which AP affected that? Also, can I get some commands or troubleshooting method to identify next happens similar issue reoccur?
    Aruba3600 / 5.0.3.3
    AP105
    Regards
    Simon
  • 2.  RE: AP105 issue fixed by AP reboot
    Posted Mar 22, 2012 12:07 AM
    Ap is congested, then when it is rebooted, all clients go away, so it seems like there are no more problems.
    What voice client is this?
  • 3.  RE: AP105 issue fixed by AP reboot
    Posted Mar 22, 2012 01:02 AM
    thanks, cjose. It is clear.
    Voice client is Alcatel Omni touch ip phone.
    Regards
    simon
  • 4.  RE: AP105 issue fixed by AP reboot
    Posted Mar 22, 2012 06:28 AM
    How far apart are you access points?
    Are the phones running on a separate SSID or the same SSID as other clients?
    What kind of encryption are you using?
  • 5.  RE: AP105 issue fixed by AP reboot
    Posted Mar 23, 2012 02:59 AM
    It is not so far, maybe 10 to 20 meter between AP and each client.
    Only same type of phone is running on one SSID.
    Encryption is WPA2 with EAP-TLS.
    I can see the number of clietns were only two to three under each AP from show ap active output before the AP reboot.
    So the number of clients may not relate to this symptom.
    Regards
    Simon
  • 6.  RE: AP105 issue fixed by AP reboot
    Posted Mar 23, 2012 03:15 AM
    For the voice protocol are you using SIP, SVP or NOE?
  • 7.  RE: AP105 issue fixed by AP reboot
    Posted Mar 23, 2012 06:44 AM
    We use NOE.
    Regards
    Saimon
  • 8.  RE: AP105 issue fixed by AP reboot
    Posted Mar 23, 2012 09:55 AM
    Are you dropping broadcasts and multicast on the Virtual AP level?  Do you have a rule that prioritizes NOE?  Do the phones show up in the "Voice Clients" portion of the Controller as NOE phones?  What band are the phones on?
  • 9.  RE: AP105 issue fixed by AP reboot
    Posted Mar 26, 2012 11:08 AM
    Cjoseph
    I didn't check during problem. Which command do I check?
    >>Do you have a rule that prioritize ONE?
     Yes, the highest.
    >>Do the phones show up in the "Voice Clients" portion of the Controller as ONE phones?
    >>What band are the phones on? EGG
    Regards
    simon
  • 10.  RE: AP105 issue fixed by AP reboot
    Posted Mar 26, 2012 10:03 PM
    @sai45mon10 wrote:
    Cjoseph
     Yes, the highest.
    Regards
    simon
    Go to Configuration> Wireless> AP Configuration.  Edit the AP-Group that your access points are in.  Expand Wireless LAN, Expand Virtual AP then click on the Virtual AP that corresponds to your WLAN.  In the right pane, make sure that drop broadcast and multicast is checked, along with Proxy Arp.
  • 11.  RE: AP105 issue fixed by AP reboot
    Posted Apr 03, 2012 06:51 AM
    Cjoseph
    It was already checked. then can i cofnirm if broadcast and multicast is drop or not in some show command?
    Regards
    Saimon
