AP105 - No faster than 54Mbps
  • 1.  AP105 - No faster than 54Mbps
    Posted Feb 02, 2012 04:51 PM
    I have 2 new AP105's on a 3200 Controller. Running OS 6.1.2.5
    All lights on the AP are green but clients never get a "N" connection. The best they can do is 54Mbps. I can take the same laptop I'm using to test to a different location with AP105's running of a a 650 Controller and N connection are fine. The 3200 is the Master Controller. The AP's lan connection is 1Gbps. I've checked the RF Management area and ensured that "High Throughput" is enabled as I've seen mentioned in a previous post.
    Any ideas are appreciated.
    #3200
  • 2.  RE: AP105 - No faster than 54Mbps
    Posted Feb 02, 2012 04:57 PM
    Forgot to mention, encryption is AES... which apparently supports N
  • 3.  RE: AP105 - No faster than 54Mbps
    Posted Feb 02, 2012 06:32 PM
    ensure that high throughput is enabled in the 802.11a and 8011 g radio profiles. Also make sure that the high throughput  is enabled in the ht ssid profile under the SSID profile.
    rf dot11a-radio-profile "AP"
      high-throughput-enable
    rf dot11g-radio-profile "AP"
    wlan ht-ssid-profile "default"
  • 4.  RE: AP105 - No faster than 54Mbps
    Posted Feb 02, 2012 06:33 PM
  • 5.  RE: AP105 - No faster than 54Mbps
    Posted Feb 03, 2012 04:04 PM
    Thanks... the High Througput enable on the SSID profile was disabled... all is well now.
    I appreciate everyones help!
  • 6.  RE: AP105 - No faster than 54Mbps
    Posted Feb 02, 2012 06:50 PM
    Can you post the output from "show ap bss-table" and "show user" (include only your user, if you want)? That will help see if everything is configured correctly.
