AP105 - Power adaptor
  • 1.  AP105 - Power adaptor
    Posted Feb 08, 2013 04:41 AM
    Does anyone know the spec for the power connector, i know 12v 2A
    But what size is the power connection?
  • 2.  RE: AP105 - Power adaptor
    Posted Feb 08, 2013 06:32 AM
    If you are using AP-AC-UN ,u may find more detailed info in the following link:
    http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Default.aspx?EntryId=9020
    Hope it will answer you needs.
    Have a lovely weekend.
    Me.
  • 3.  RE: AP105 - Power adaptor
    Posted Feb 08, 2013 11:11 AM
    If you want to use a locally sourced alternative for the adapters Aruba offers (AP-AC-UN or AP-AC-12V18):
    - 12V +/- 5%
    - 15W or higher
    - DC plug: 1.7/4.0mm center-positive circular plug with 9.5mm length
