AP105- Speed stuck at 100Mbps.
  • 1.  AP105- Speed stuck at 100Mbps.
    Posted Mar 13, 2014 09:07 PM
    hi,
    We have a 3200 Controller and it is connected to 25 AP's .
    Few AP transmitting at 100MBPS with a red flashing light and few at 1Gbps speed with green flashing light.
    I tried changing the ports, changing the POE injector, using ports and injectors which deliver 10Gbps speed on the low speed AP.
    I also upgraded the controller's OS version to the new 6.3.1, still the same.
    Nothing worked with this AP transmitting at 100Mbps. What am I missing ?
    Santhosh.
    #3200
  • 2.  RE: AP105- Speed stuck at 100Mbps.
    Posted Mar 13, 2014 09:09 PM
    Are you able to test the cable with a tester? How about plugging in a
    laptop?
  • 3.  RE: AP105- Speed stuck at 100Mbps.
    Posted Mar 13, 2014 09:12 PM
    Hi Tim,
    How do you connect a Ap in a laptop?
    I have used a cable from a Ap which is transmitting at 1Gbps.
    Santhosh.
  • 4.  RE: AP105- Speed stuck at 100Mbps.
    Posted Mar 13, 2014 09:17 PM
    Ok, yes I meant use the cable feeding the AP on the laptop.
    Does anything look out of the ordinary when you do a show interface status
    on the switchport while the AP is plugged in?
