AP115 is not working on VirtualRF
  • 1.  AP115 is not working on VirtualRF
    Posted Oct 23, 2014 01:17 AM
    Hi
    I'm use VirtualRF  on Airwave version 7.6.2 ,
    When I add AP 115 on Plan heatmap is not working  but  If  i use  AP 105 instead heatmap is working
    Thx
  • 2.  RE: AP115 is not working on VirtualRF
    Posted Oct 23, 2014 09:50 AM
    AirWave 7.6 supports up to AOS 6.1.3. The AP-115 minimum supported version is AOS 6.3.1.0.
    Per the AirWave 8.0.1 Release Notes it looks like AP-11x support was added in 8.0.1.
  • 3.  RE: AP115 is not working on VirtualRF
    Posted Oct 23, 2014 10:29 AM
     Marcus  ,
    Thx for support
