Aruba Instant Wi-Fi: Meet the controllerless Wi-Fi solution that's easy to set-up, is loaded with security and smarts, and won't break your budget.
AP12 - Guest data limitation
  • 1.  AP12 - Guest data limitation
    Posted Jul 05, 2022 03:12 PM
    Good day,
    I need to setup Guest WiFi network that limits the data usage as well as limits the speed. I have managed to limit the speed of the guest network but cannot see any settings to limit the amount of data used per client on the guest network? This limit should also reset daily.
    Could you please let me know if this is possible and if so how would i configure?
    Thank in advance.
    Christo
  • 2.  RE: AP12 - Guest data limitation
    Posted Jul 05, 2022 07:13 PM
    usually you can do this when using ClearPass which keeps track of total amount of data used fro clients using RADIUS accounting.
