AP125 Radio LED stays Amber
  • 1.  AP125 Radio LED stays Amber
    Posted Jan 31, 2012 03:04 PM
    Problem: AP125 has the b/G and N Radio LEDs flashing Amber it could mean the following:
    Amber: radio not configured for HT
    If HT is configured, then check the 802.11 Security under the SSID Profile and check the Network Authentication Mixed Mode and you will get the Amber LEDs flashing if the security was set to dynamic-wep
    Does anyone else or has anyone else had this problem?
    #AP125
  • 2.  RE: AP125 Radio LED stays Amber
    Posted Jan 31, 2012 10:39 PM
    If they are flashing, the AP is setup as an Air Monitor (AM)
  • 3.  RE: AP125 Radio LED stays Amber
    Posted Feb 01, 2012 12:45 AM
    If a device is an AM on both or either band, the band light will be blinking no?
  • 4.  RE: AP125 Radio LED stays Amber
    Posted Feb 01, 2012 01:46 AM
    yes thats correct.
