AP125 will not power up after rebuilding 620 controller.
  • 1.  AP125 will not power up after rebuilding 620 controller.
    Posted Feb 18, 2014 04:50 PM
    I had to reconfigure Aruba 620 controller to recover from issue. Upon recovery, I noticed that PoE is not working none of my APs will power up now. Do I have to reset the APs as well?
  • 2.  RE: AP125 will not power up after rebuilding 620 controller.
    Posted Feb 18, 2014 04:57 PM
    Are these APs plugged directly into the controller?
    Also, did you do a write erase all on the controller?
  • 3.  RE: AP125 will not power up after rebuilding 620 controller.
    Posted Feb 18, 2014 05:14 PM
    Yes these are plugged up to the controller and I did perform an write erase all
  • 4.  RE: AP125 will not power up after rebuilding 620 controller.
    Posted Feb 18, 2014 05:16 PM
    Write erase all will wipe all licenses from the controller. The 620 actually needs a license key to enable PoE. You'll need to check your licensing.arubanetworks.com account or contact support to get the key.
  • 5.  RE: AP125 will not power up after rebuilding 620 controller.
    Posted Feb 18, 2014 05:17 PM
    Thanks, I appreciate your help.
  • 6.  RE: AP125 will not power up after rebuilding 620 controller.
    Posted Feb 18, 2014 05:18 PM
    What if the device is out of support, will they still give you your keys?
  • 7.  RE: AP125 will not power up after rebuilding 620 controller.
    They should. It is tied to the hardware.
  • 8.  RE: AP125 will not power up after rebuilding 620 controller.
    Posted Feb 18, 2014 05:19 PM
    Excellent. I will call them, thanks again
  • 9.  RE: AP125 will not power up after rebuilding 620 controller.
    Posted Feb 18, 2014 06:18 PM
    If you have a licensing account, you can log in and click 'import preloaded certficiates' and input the serial number of the controller to retrieve the embedded PoE license.
  • 10.  RE: AP125 will not power up after rebuilding 620 controller.
    Posted Feb 18, 2014 07:19 PM
    I am logging in to the service right now. Thanks for all the help. I will report back my findings
