AP134 and Power Injector
  • 1.  AP134 and Power Injector
    Posted Mar 28, 2014 12:14 PM
    Hi All,
    I have the following strange behavior regarding AP134.
    If I connect them on POE switches (802.3af) they work without problems.
    I have an error about the insufficien POE voltage on eth1 but I have read on the manuale that it's correct:
    Shutting down eth1 due to insufficient POE voltage
    If I use power injectors, AP134 power on (power led is green), but the eth0 port is not able to goes up:
    Starting Kernel AESGCM KAT ...Completed Kernel AESGCM KAT
    Domain Name: arubanetworks.com
    No panic info available
    init mv_cesa ok
    Ethernet port 1 mode: active-staEthernet Channel Bonding Driver: v3.5.0 (November 4, 2008)
    ndby
    eth0: link down
    ADDRCONF(NETDEV_UP): eth0: link is not ready
    ADDRCONF(NETDEV_UP): bond0: link is not ready
    eth0: link down
    bonding: bond0: enslaving eth0 as a backup interface with a down link.
    eth1: link down
    bonding: bond0: enslaving eth1 as a backup interface with a down link.
    AP xml model 50, num_radios 2 (jiffies 2496)
    init_asap_mod: installation:0
    radio 0: band 1 ant 1 max_ssid 16
    radio 1: band 0 ant 1 max_ssid 16
    ethernet_device_event: dev eth0 is up
    Starting watchdog process...
    Getting an IP address...
    Time out
    The ETH0 led is not power on.
    If I connect on the same power injector an AP105, it works without problems....
    Is it possible?
    Someone can help me?
    Gian
  • 2.  RE: AP134 and Power Injector
    Posted Mar 28, 2014 01:38 PM
    What is the model power injector?  The AP125 could draw more power than the AP105.
  • 3.  RE: AP134 and Power Injector
    Posted Mar 29, 2014 03:55 AM
    Thanks Cjoseph for your support.
    The power injector is a common object (ARP product).
    From the AP134 DS I read:
    POWER
    • 48 volts DC 802.3af power over Ethernet (PoE) or 802.3at PoE+
    - Note: when using 802.3af POE, the second Ethernet port is disabled. It is enabled when using an 802.3at POE power source (or direct DC power).
    I was hoping that 802.3af was enough.
    Best Regards
    Gian
  • 4.  RE: AP134 and Power Injector
    Posted Mar 29, 2014 07:30 AM
    gianti81,
    I would try a different model of power injector and see if you achieve the same result, because they are not all created equal.  It does work with POE.
