AP135 in reboot loop with any IAP images
  • 1.  AP135 in reboot loop with any IAP images
    Posted Feb 07, 2014 09:37 PM
    Hello
    I'm fiddling with an AP135 that I'm trying to get to work.
    Unfortunately, I *think* it might be a case of Flash being corrupted/Defect, and I'd like to have a second opinion before chucking it.
    After trying 5-6 various IAP images from the download site, I always get the same state/result
    Ex:
    Upgrade with latest IAP image:
    apboot> upgrade os 192.168.0.10:ArubaInstant_Cassiopeia_6.3.1.2-4.0.0.3_41784
    eth1: up, 100 Mb/s, full duplex
    Using eth1 device
    TFTP from server 192.168.0.10; our IP address is 192.168.0.111
    Filename 'ArubaInstant_Cassiopeia_6.3.1.2-4.0.0.3_41784'.
    Load address: 0x2000000
    Loading: #################################################################
    done
    Bytes transferred = 6308284 (6041bc hex)
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    Erasing flash sector @ 0xf8100000....................................................................................................done
    Erased 97 sectors
    Copying to flash...
    Writing ..................................................................................
    No error pertaining to device type/model, so right image.
    Image transfer is successful, Certs are OK, Checksum OK, Sig OK... no problems on the TFTP transfer.
    AP then reboots after writing:
    APBoot 1.2.5.0 (build 27650)
    Built: 2011-03-30 at 13:34:38
    Model: AP-13x
    CPU: 88F6560 A0 (DDR3)
    Clock: CPU 1600MHz, L2 533MHz, SysClock 533MHz, TClock 200MHz
    DRAM: 256MB
    POST1: passed
    Flash: 16 MB
    Power: 802.3af POE
    LAN: done
    PHY: done
    PEX 0: RC, link up, x1
    bus.dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
    00.00 00 11ab 6560 00005 02 f1000000 00000000 00000000 00000000
    00.01 00 168c 0030 00002 01 90000000 00000000 00000000 00000000
    PEX 1: RC, link up, x1
    01.00 00 11ab 6500 00005 02 f1000000 00000000 00000000 00000000
    01.01 00 168c 0030 00002 01 94000000 00000000 00000000 00000000
    Net: eth0, eth1
    Radio: ar9390#0, ar9390#1
    Hit <Enter> to stop autoboot: 0
    Checking image @ 0xf8100000
    Copying image from 0xf8100000
    Image is signed; verifying checksum... failed! 0xfa3b7d00
    Checking image @ 0xf8800000
    Invalid image format version: 0xc
    eth0: down
    DHCP broadcast 1
    DHCP IP address: 192.168.0.111
    DHCP subnet mask: 255.255.255.0
    DHCP def gateway: 192.168.0.1
    DHCP DNS server: 8.8.8.8
    DHCP DNS domain: jumpspace.ca
    ADP multicast 1
    Abort
    apboot>
    Image checksum failure and reboot loop starting.
    Anything more to do before declaring it Dead as a Doorstop?
    #AP135
  • 2.  RE: AP135 in reboot loop with any IAP images
    Posted Feb 07, 2014 09:50 PM
    Is this an IAP-135 or is it an AP-135 you are trying to load IAP code onto?    The only visual indication is a white sticker on the back of the AP that would say "IAP-135-US".
  • 3.  RE: AP135 in reboot loop with any IAP images
    Posted Feb 07, 2014 09:54 PM
    Ha, there's the reason then...  I thought I did my homework, seems like I missed something
    the sticket says "AP-135"...
    Any ways to make it into an Instant AP, or are they hard-locked?
  • 4.  RE: AP135 in reboot loop with any IAP images
    Posted Feb 07, 2014 09:56 PM
    A controller-based AP, like the AP-135,  cannot be converted to an IAP.
    An IAP, however, can run as either an IAP or managed by a controller.
  • 5.  RE: AP135 in reboot loop with any IAP images
    Posted Feb 07, 2014 10:00 PM
    Oh well, I guess I'll swap it for another one in our lab
    Thanks for the info!
