AP135 Password Recovery failed
  • 1.  AP135 Password Recovery failed
    Posted Sep 18, 2014 12:56 PM
    Hello all.  I tried to perform a password recovery on an AP135.  Consoled in, at the "User:" prompt I used "password" and "forgetme!".  It takes me right back to a "User:" prompt.
    Any ideas what I'm missing?
  • 2.  RE: AP135 Password Recovery failed
    Posted Sep 18, 2014 12:59 PM
    Are you consoled in to the AP acting as the Virtual Controller?
  • 3.  RE: AP135 Password Recovery failed
    Posted Sep 18, 2014 01:10 PM
    I sure thought I was.  The install was a little messed up...60 Aruba AP's plugged into Brocade switches.  Brocade switches plugged into Cisco switches.  The Cisco switches were supposed to have the Brocades on their own vlan (that didn't happen).  So 8 of the AP's were able to see each other on the correct vlan and were configured properly.  The rest were isolated and never picked up the correct config.
      I finally go the Cisco's configured properly so all of the AP's are on the same vlan.  They didn't pick up the correct config, so powered them all off except for the one that has a static address (which I assume was acting as the virtual controller).
    How would I find out if I can't get into it?
  • 4.  RE: AP135 Password Recovery failed
    Posted Sep 18, 2014 06:03 PM
    So these are IAP135s? Do you know the version running on them?
    Sent from my iPhone
  • 5.  RE: AP135 Password Recovery failed
    Posted Sep 18, 2014 09:05 PM
    No, they were purchased about a year ago.
